Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Place your Ad Here!
Old 06-09-2013, 07:32 PM
largetony86 largetony86 is offline
Vehicle: 2002 dodge Ram
largetony86 is on a distinguished road
Default E brake problem
My e-brake doesn't hold my truck at all. the cable has a good amount of slack in it. The problem is I can't get the nut to turn in order to tighten the cable. What do I need to clamp onto to hold the entire unit in place so I can turn the nut to tighten the cable? Thanks for any help you can give.
Old 06-10-2013, 07:37 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
First off, spray some penetrating oil all over the nuts and threads and let it sit for quite a while. This should really help loosen them off. Then hold the assembly with a vice grips and turn the nut.
