Old 06-09-2013, 08:09 PM
nevadaboy nevadaboy is offline
Vehicle: 2012 Dodge Ram
Rep:20
nevadaboy is on a distinguished road
Default 2500 and 3500
Hey guys I'm thinking about trading in the hemi on a cummis and was jus wondering what size lift and what kind on gas mileage your getting?
Old 06-09-2013, 09:02 PM
You can run 6" or 8" BDS
Another member here has the 5" RCX
Without doing a delete you won't see that much more of an improvement of MPG over the Hemi
But you'll be able to lug around those heavier wheels
Old 06-10-2013, 12:00 PM
Kcbigbadram's Avatar
Vehicle: 2014 1500
Trim Level: limited
Rep:497
that is the 6" BDS standard arm lift. BUT im thinking of upgrading to the 8" kit. should of went all out to start with
Old 06-10-2013, 12:33 PM
Then you will need larger tires......
But if you want to upgrade, let me know and I will get you the kit to convert it
Old 06-10-2013, 12:35 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
Yeah, I usually average around 16 to 16.5 mpg combined city/highway. But I once averaged 20 mpg on a trip to the beach in slow traffic running 55 mph most of the time. I'm running a 5 inch RCX lift and 355/60-20 (37x14.00) Terra Grapplers with 3.73 gears. I'm also deleted, which as mentioned, makes a huge difference.
Old 06-10-2013, 12:40 PM
You almost got me calling my dealer for a moment till I read your last line.....that you are deleted.
I cant delete where I am at
Mind you I do get 15.5-16.5 MPG now with my current setup.
Slap on a Supercharger and I should be able to increase that by 1-3 MPGs.
Old 06-10-2013, 12:47 PM
Wandell's Avatar
Rep:35
Yeah, bone stock I never saw the dash indicator go higher than 16.5 with the tiny 31 inch stock tires. And after several hand calculations, the dash indicator is usually 0.5 mpg optimistic.
Old 06-10-2013, 01:07 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:221
My truck is an early 04, 4.10 gears, quad cab, short bed, 4x4, 4.10 gears. I'm not sure if my truck is just leveled, or has a lift front and back. I think its just leveled, but if it is lifted, its small, maybe 2", but I have stock tires. I could easily run a larger tire, but won't switch until my current tires are worn out.
I'd say I average around 15 mpg of mixed driving. I've never gotten much better than 17 mpg, but I've never gotten worse than 12 mpg, and that was towing. My experience is that my Cummins gets better mileage around town than a 1/2 ton gasser, and about the same on the highway. Keep in mind that lifts, lareger tires and good fuel mileage don't go well together.
Old 06-10-2013, 02:49 PM
That was with the tiny wheels too
Yea, the OP is going to more than likely lift and wheels (if you have seen his current truck, you will know)
Old 06-10-2013, 03:54 PM
Vehicle: 2014 1500
Trim Level: limited
Rep:497
when i did my lift and wheels/tires i only lost about 1 mpg. these diesels dont seem to lose as much with a lift as a gas truck does
