Old 06-10-2013, 09:11 AM
NickGalloway NickGalloway is offline
Vehicle: 2007 Dodge Ram 1500 5.7Hemi
Trim Level: SLT Big Horn Edition
NickGalloway is on a distinguished road
Default Pressure line Booster
So apparently, the $50 sonnax line pressure booster is just a 2.2 k Ohm resistor. I researched it for a while and found a DIY to make your own, but as i was making it i realised that all I needed to do was add the resistor to the factory wiring. Boom, $5 pressure line booster. 10 min install.
If you are not aware of the DIY, locate the plug on the transmission (45, or 545 rfe) and use the two wires located towards the front of the truck. There is a solid colored wire, and a white one with a stripe on it. If you're looking for a cheap easy MOD i would recommend doing this.
Old 06-10-2013, 10:16 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
I've had the Sonnax for a few years now,
The effect only lasts a couple weeks until the PCM adapts and goes back to normal.
You have to remove it and drive for a week or so without it,
then re-install it to get the kick-in-pant shift firmness again.
Kind of a pita after a while so only did it when a track day was coming up.
My new MGH L&M Customs tranny will get a "Real" pressure boost soon to run with my RIPP supercharger.
Old 06-11-2013, 01:10 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Nice dude you decided to go with MGH congrats and smart move BTW!!!!
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
