MDS clicking and warranty denied! - Page 11 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 06-27-2013, 06:59 PM
GrayhemiST GrayhemiST is offline
Vehicle: 2012 Ram Hemi Regular Cab
Color: Mineral Gray
Rep:277
GrayhemiST is a jewel in the roughGrayhemiST is a jewel in the roughGrayhemiST is a jewel in the rough
One thing to take into consideration is this all started happening when Cliff got an engine light one night, his engine started to run bad and would give hesitation when giving it gas, he checked the engine code with his tuner and it said mis fire cylinder 8, yet cliff ran the truck for over 3 - 4 hrs with it running bad that night cause he had important stuff to do.
http://www.ramforumz.com/showpost.ph...67&postcount=1
Usually not a good idea to run a truck that has engine issues for that long at city and highway speeds and hope nothing will break or over heat or bend or get abused prematurely. Just that 3-4 hr time frame of issues could be the reason that this engine is dying prematurely. JMO
A lesson for ALL of us to learn....
Old 07-02-2013, 05:05 PM
viperr817's Avatar
viperr817 viperr817 is offline
Vehicle: 2012 ram
Rep:195
viperr817 has a spectacular aura aboutviperr817 has a spectacular aura about
Any more updates clifford?
Old 07-03-2013, 02:25 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Hope things worked out....Any update.....
Old 07-03-2013, 03:22 PM
Graygoose's Avatar
Graygoose Graygoose is offline
Vehicle: 2015 Ram Bighorn
Trim Level: Bighorn
Rep:110
Graygoose will become famous soon enoughGraygoose will become famous soon enough
93 tune and after mileage increase? Ah, maybe try to sell that to the service manager, we all know
Hope you didnt put the 93 tune in, get detonation and bust a ring or get a hole in your piston.
2015 Crew Cab Bighorn
Old 07-05-2013, 12:02 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
just stopping by looking to see if op has updated the thread.
Old 07-05-2013, 08:45 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Yes it would be nice if the OP was as generous with his post on whats happening as he is on his post about his problems
Old 07-05-2013, 11:08 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Unhappy
I don't believe a tune or his mods has anything to do with this problem. And to Graygoose...no pun intended, if he had burned a hole in a piston oil would be forced out by compression through crankcase ventilation. You would see blue smoke from hell coming out the exhaust and oil being forced out of the filler cap hole...highly unlikely....ESPECIALLY half to full throttle. I would guess that if there is an oil burning and ticking problem it is from the valve train only. Could be a bent valve not closing or seating causing low compression. And the burning oil could be from the damaged valve guides. Even an idiot mechanic would know to look for rocker arm breakage, bent push rods, bad lifters. He says there's bad shaking when in 4 cylinder mode....lifter could be bad right there. In any case the valve train sounds like the culprit. And I would be kicking some dealers bunholes if it were my truck.....a 2012 truck...jeezem! They owe him a repair to say the least. They should stop with their dumb a$$ excuses and tear the engine down....PERIOD. There could be some other issues, but the valve train most likely caused them....my opinion.
Old 07-07-2013, 01:38 AM
Rep:783
pre detonation could cause that? the detonation could be caused by a faulty tune?
Old 07-07-2013, 11:58 AM
Color: Mineral Gray
Rep:277
No news is good news.........I guess?
Old 07-07-2013, 03:02 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Let's hope you are right.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
