Oil Filter Change on 3.6 Penstar - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 08-03-2014, 11:44 AM
RamFishTruck RamFishTruck is offline
Vehicle: On Order 2014 Ram 1500
Trim Level: QC BigHorn
Color: Black Gold Pearl
RamFishTruck is on a distinguished road
Originally Posted by Bigbird View Post
You did get a very good deal. I'm sure Bosch filters are just fine but for now I'm sticking to the Mopar filter. In the future I'll probably try a Bosch filter.
The Bosch filter 3335 did not work properly as it caused the oil pressure light/gauge and the malfunction light to come on. Took it down the dealer and they got a code reading off the computer saying their was a problem with the oil filter. Put in the mopar and all was good again.
Looking back at the Bosch, the book at AZ said the the 3335 was recommended for the 3.6L from '09 thru '13. Didn't have any info on '14 so I assume there was a slight change between '13 and '14 filters. Anyway, go with the Mopar to be safe, only $10 at the dealer.
2014 Bighorn QC, Black Gold Pearl, 3.6L Pentastar, 6' 4" Box, 4WD, 3.55 Gears, Limited Slip, Air Suspension, Remote Start, Back Up Camera, Front & Rear Parking Sensors, Heated Seats & Steering Wheel, 9 Speaker Alpine Sound System, U-Connect 8.4A, Rear Defroster, Comfort group, Luxury Group
Old 08-03-2014, 11:52 AM
Bigbird's Avatar
Bigbird Bigbird is offline
Vehicle: 2017 RAM 1500QC, 8 speed, 3.21
Trim Level: Lone Star
Color: Delmonico Red Pearl
Rep:44
Bigbird is on a distinguished road
Thanks for the heads up. I will stick with the MOPAR filter.
Old 03-25-2016, 10:18 PM
brentwasham brentwasham is offline
Vehicle: 2013 Ram 1500 Quad Cab
Trim Level: Tradesman
Color: Metallic Red
brentwasham is on a distinguished road
deleted due to technical problem on site.
Last edited by brentwasham; 03-26-2016 at 05:38 PM. Reason: Had to update my truck and find earler post to quote, sold the 2002 Dodge Ram, love the 2013 with Pentastar engine!
Old 03-25-2016, 10:32 PM
Bigbird's Avatar
Rep:44
Sorry you had so much trouble. This thread is dedicated to Oil Filter Change on 3.6L V6 Pentastar. You could go over to a V8 thread where they might find this information more useful.
Old 03-25-2016, 10:39 PM
Color: Metallic Red
Default Tough Oil-Change Day
[Hi, great write up and pics .. going to do my own change .. as the 1st change at the costed more than I expected .. question .. the Oring .. it is the ring for the cap ? it is the seal between the plastic cap and the filter housing ?] Yes, the ring goes in the wide gap just above the cap threads. I just finished my second change today and ran into a couple of pitfalls. First, HIGHLY recommend replacing the factory aluminum drain plug with a steel one. My first change I noticed that I had to push on the socket to get it to grab the plug head, should have replaced it then. Today the six-point 13 mm Craftsman socket rounded the head. Finally got the plug out using a Craftsman "Bolts Out" socket (set is $25). It also took a 3' cheater bar for leverage in the tight space under the truck. I know I didn't put the plug in that tight, they seem to get tighter between changes! Put in the new steel plug from O'Reilly Auto Parts (#65324), then realized that I had the wrong filter cartridge, a Fram "Extra Guard" CH11665 purchased at Walmart. Turns out the plastic end on the cartridge is different depending on year model. I have a 2013, it was changed for 2014 and later. So back to O'Reilly for the right filter. The Microguard MGL57526 worked fine on my 2013 3.6L. Hopefully you won't have these problems!
Last edited by brentwasham; 03-26-2016 at 05:34 PM. Reason: Post I replied to was earlier, had to quote it before my text.
Old 03-25-2016, 10:50 PM
Color: Metallic Red
Default Tightening oil filter cap
I used a 15/16" open end wrench to tighten the filter cap. Turns out if will just fit between the two solid air conditioner lines allowing almost a quarter turn at a time. When the cap was threaded nearly all the way in, I determined it was tight enough by putting my finger nail between the cap flange and metal housing each time I tightened a quarter turn. When I could no longer get fingernail in the gap figured it was touching or close enough that oil ring was certainly all the way into the housing and providing a tight seal. Don't forget to look for leaks with truck running, I once lost four quarts of oil on one of these German O-ring filter assemblies.
Old 03-26-2016, 05:10 PM
Color: Metallic Red
Default Correct Fram Filter for 2013 ONLY 3.6L Ram
If you go to Walmart, the correct Fram number for the Extra Guard oil filter for a 2013 ONLY model is CH10955. it was over $10 at my local store, online shows $8.87. The MicroGuard MGL57526 available from O'Reilly is only $5.99, appears pretty similar.
Old 03-26-2016, 05:19 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:273
namretsud is a jewel in the roughnamretsud is a jewel in the roughnamretsud is a jewel in the rough
I will only use Mopar or Wix manufactured filters.
Old 03-26-2016, 05:41 PM
Bigbird's Avatar
Rep:44
Only Mopar MO-349 for my 2014 RAM.
Old 06-14-2016, 02:34 PM
Huffpuff's Avatar
Huffpuff Huffpuff is offline
Vehicle: 2016 Ram
Trim Level: 1500 Quad Cab
Huffpuff is on a distinguished road
Yes, never use Fram filters on anything.
