Old 06-10-2013, 08:12 PM
MaxPower1971's Avatar
MaxPower1971 MaxPower1971 is offline
Vehicle: 1993 250--1994 2500--2005 2500
MaxPower1971 is on a distinguished road
Default Transmission Question
Hey guys long time no post!!
when going to work last week, I noticed my truck would not go into overdrive. It was working perfect the day before. I get the nice 1-2-3-4 and usually at 55MPH overdrive would kick in, BUT when I push my OD button, it works (truck RPM raise and 1 gear down......) but the gear I used to have at 55 is gone. Someone said to try to swap OD and HORN relays, but I dont see an OD relay in the underhood box...
Any ideas? Pointes as to where to look at??
1994 2500 4X4 5,9 gasser
Thank you in advance!!
MaxPower
Old 06-11-2013, 10:02 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
Is the CEL on?
Have you checked the tranny fluid level?
Drive until up to operating temperature
Park and place e-brake
Put in N
Pop Hood and check the Tranny fluid
Also, the shifting is: 1 - 2 - 3 - Tconverter lockup - OD (4th)
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 06-11-2013, 07:19 PM
Sorry I forgot to be specific loll
CEL is on but was on since I cut the o2, (code 21)
I have an EGR code (code 32) that's been there for a few months (still trying to figure out that one lol)
and the tranny code 37, that's been there since I bought the truck new in 1995 (it's a 94)
Fluid is fine, no foul smell, level good. It's overdue for a change but I don't think that's the culprit. I suspect the OD solenoid but it's not throwing the code.....Any ideas??
MaxPower
Old 06-12-2013, 10:43 PM
sbrodacz sbrodacz is offline
Vehicle: 96 dodge ram
sbrodacz is on a distinguished road
Have you reread the codes and see if it is showing a separate code?
