Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 06-10-2013, 10:29 PM
jdsgtball jdsgtball is offline
Vehicle: 2002 Dodge Ram 1500 4X4
jdsgtball is on a distinguished road
Default Ram Sputtering
I own a 2002 Dodge Ram 5.9(360) 4 wheel drive. It has been great it has 135,000 miles on it and really hasn't given me many problems. I do have one however after every start up with in the first few hundred feet it sputters and runs rough, and then every time I step on the accelerator it seems it wants to die. It will do this for a few minutes and then goes away and wont do it again till the next start up. Oh yea if I burry the accelerator to the floor and it goes like a bat out of hell then is fine as well after that. What do you guys think might be the problem??? Any help will be appreciated!!!!!!!
Jim
Old 06-11-2013, 12:40 AM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Rep:194
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
When was the last tune up? Plugs wires cap rotor seafoam in the fuel system, throtle body cleaning. Need more info.
Old 07-01-2013, 09:41 PM
RAM2003 RAM2003 is offline
Vehicle: 2003 Dodge Ram
Color: RED
RAM2003 is on a distinguished road
Default Any Fixes
I have a 2003 Dodge Ram with the same issue. Were you able to come up with a solution? I replaced my TPS sensor but it didn't fix the issue.
Old 09-05-2013, 08:39 PM
theLAW's Avatar
theLAW theLAW is offline
Vehicle: 2001 Dodge Ram
theLAW is on a distinguished road
OMG! I am having the same issues! Mine started about two days ago and does it every time it sits for more than a couple hours. I took it to one mechanic and he said that by the looks of it, it could very well be a fouled up injector which I'm REALLY hoping not. According to him, these engines are notorious for bad injectors given the fact they have no return line but idk I'm going to get second opinions before I do anything.
Old 09-08-2013, 05:43 AM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
ramretsud, gives the answer. First tune it up, then put a can of Seafoam in your gas tank (whether the tune up helps or not). I've owned a 98 1500 360 a long time. R...
Old 10-14-2013, 10:46 AM
RyanLee25 RyanLee25 is offline
RyanLee25 is on a distinguished road
I am having a similiar issue. I did a complete tune-up, no joy. Still having the same issue. I took out my IAC and cleaned it up and for 1 drive it did good. So I am going to replace it with a new one and see how it goes.
