Old 06-11-2013, 07:25 PM
SilverRam318's Avatar
SilverRam318 SilverRam318 is offline
Vehicle: 2011 Bighorn Dodge Ram
Color: silver
SilverRam318 is on a distinguished road
Default Lift Help Newbie
OK so I have a 6 inch zone lift on my RAM then installed billsteins at 1.4. Then moved them to 2.8. However took it to shop today to have a rear coil replaced and they said that the billsteins are doing more damage then good to my truck? they said that the zone preloaded spacer in the front has to be removed and left out the truck in order to properly install the bilsteins said causes to much stress on coil? Was the zone spacer supposed to be removed permatley to install billsteins? any help would be appreciated
Old 06-12-2013, 02:13 AM
Chickenhole's Avatar
Chickenhole Chickenhole is offline
Vehicle: 2011 ram sport
Rep:21
Chickenhole is on a distinguished road
How does your truck drive with the bils @ 2.8? Lots of guys run bils on top on their suspension lift.
4" MOPAR LIFT, BILSTEINS@2.1, 12" REAR BILSTEINS, 1.5 TGC COIL SPACER, 325/60/20 NITTO TERRA GRAPPLERS, AFE STAGE 2, XD ROCKSTARS
Old 06-12-2013, 10:28 AM
fastNugly @ BP fastNugly @ BP is online now
Rep:1804
yes they are right!!!
REMOVE THAT PRE-LOAD ASAP!
You CANNOT stack a pre-load and the Bilsteins. The only thing that stays is the strut spacer block.
But I am guessing the Bilsteins are already installed and they did remove the pre-load? If so, that is a good thing.
Plus, it would be VERY difficult to install the Bilsteins with that pre-load in and your CVs would be jacked at a ridiculous angle
Old 06-12-2013, 12:45 PM
Rep:2051
Yup, what fastNugly said ^^ You definitely can't be running the preload spacers on Bilsteins. Remove those and just set your Bilsteins to the height you want. I could see 2.8" really pushing the limit. What are you control arm and CV shaft angles like with the Bilsteins that high? I'd consider putting them down to 2.1" to be safe.
Old 06-13-2013, 10:44 PM
Color: silver
thanks for the help guys.
Now I have a new problem I took in to my shop today and we removed the small preloaded spacer but didnt really make much difference in height. Ive went to shops all around Delaware and nobody knows how to work on bilsteins? I just want to get as close as level as i can but im running into problem after problem. Now the driver side of the truck is sitting about a inch lower then the passanger both sides are on 1.4 setting and the lift shop said the bilsteins are causing the problem( we swapped the rear coils thinking maybe that and nothing). Any ideas? Every shop has pretty much given up on me saying just deal with the rake and hope the trucks leans back to level. im starting to regret the lift i had no idea this kinda problems came with it
Sorry posted in wrong thread earlier
