How much payload to need airbags? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 06-11-2013, 08:38 PM
Tippmannr Tippmannr is offline
Vehicle: 2010 Ram 1500
Tippmannr is on a distinguished road
Default How much payload to need airbags?
My buddy told me that when he had just his quad in the box (~700lbs) it was really squatting (hitting the bump stop frequently) and no fun to drive. Will it be worthwhile for me to put them in my truck? I will have sleds and ATV's in it pretty often.
Thanks
Old 06-11-2013, 09:28 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
The Airlift 1000's for $88 are definitely worth it!
Old 06-12-2013, 10:14 AM
OK, thanks. Can you install them without a spring compressor or dropping the rear end?
Old 06-12-2013, 12:48 PM
Moderator
Rep:2140
Yup. The way Airlift's instructions say to install them is to fold them up and slide them into the coil spring. However I could see that making the rest of the install somewhat difficult. I don't see it being easy to connect the airlines to the bag once it's already in the coil. I just dropped my rear end, removed the springs, ran my airlines, hooked them up to the bags, and reassembled the whole thing. Made life a lot easier. And it's not like it's very hard to drop the rear end.... you literally only have to under the bottom shock bolts.
Old 06-12-2013, 01:57 PM
highlandchef's Avatar
Trim Level: SLT Big Horn
Rep:220
Absolutely. Just jack the truck up, put jack stands under the frame and let the wheels drop. There is plenty of room with the springs extended to get the airbags in. The air lines are easy to run after that. Shouldn't take more than an hour or so.
Old 06-13-2013, 07:04 AM
Otterdriver's Avatar
Otterdriver Otterdriver is online now
Vehicle: 2009 SLT MegaCab
Rep:171
I just installed a set yesterday, found a couple of 4x4 blocks of wood and took my scissor jack and raised the back of the truck under my receiver, only high enough to unload the suspension leaving the rear tires still on the ground. I didn't have jack stands, so this worked very well, it left enough room to attach the air lines to the top of the airbags. I am anal so it took me a couple of hours, I wasn't in a hurry to route things. On the factory receiver there was a hole on either side of the receiver opening which worked out perfect for mounting the filler points. I chose to run separate lines, I just pulled my travel trailer out of storage yesterday, I set the bags at 20 psi, and there was zero squat. The ride quality was awesome.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ EFI LIVE 75 HP TOWING TUNE/ OD TUNE/ CARLI ADJUSTABLE TRACKBAR
