Old 06-12-2013, 07:42 AM
98rumblebee's Avatar
98rumblebee 98rumblebee is offline
Vehicle: 1998 Dodge Ram 1500
Color: Yellow + Black
98rumblebee is on a distinguished road
Default Caliper won't stop leaking
Hey y'all. I just replaced a front caliper on my 98 1500. Put new copper washers on it, bolted everything down, and it leaks brake fluid when you push the pedal. Took it off, made sure everything was good, put it on again. Still leaks fluid. Tried new washers multiple times, the thing won't stop leakin. I'm getting real frustrated... any ideas?
Put a good dip in
Old 06-12-2013, 07:59 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Rebuilder may have screwed up the threads, bolt may be bad (Rubber line), maybe even the rubber line.
Old 06-14-2013, 08:58 AM
Real embarrassed to say this but I owe y'all the solution... it turns out that with the dinky little wrench I was using I simply couldn't tighten the bolt enough... I grabbed a ratchet and jammed it on there until I thought it would break the bolt... no more leak.
Put a good dip in
