Old 06-12-2013, 12:18 PM
Rammin88 Rammin88 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:20
Rammin88 is on a distinguished road
Question Purchased a K&N air intake
Just purchased a K&N 63 series for my 2011 Hemi. Is there anything I should be aware of installing it/after installing it? Will my truck's computer pick up the difference in air flow and be ok?
Old 06-12-2013, 12:29 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
The main thing to be aware of is not damaging the air temp sensor that's located in the intake tube. And also making sure you install it correctly in your new intake.
The computer will keep your truck running exactly as it should with the new intake. It is however a good idea to disconnect the negative on your battery as you do the mod to reset the computer. This will let it "re-learn" the truck with the new intake which will help it run a little better off the bat.
Old 06-12-2013, 12:58 PM
Rep:20
Thanks!.....I'm also considering a Mufflex 18. Does anybody know the part number for it or can link me to it? I have the Big Horn Dual tip stock exhuast.
Old 06-12-2013, 02:11 PM
Rep:20
sorry, meant magnaflow not mufflex
Old 06-12-2013, 02:29 PM
Rep:2032
Here you go.
http://bullysperformance.com/stainle...5e99381cffb262
Old 06-14-2013, 08:20 AM
Rep:20
I see some people say that the outlet is 2.5" and some other people say its 2.25". Which is it?
Old 06-15-2013, 11:12 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
We always recommend the 3" inlet dual 2.5" outlet if you have factory duals.
Thanks
Jeremiah
