Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Washing & Waxing
Washing & Waxing Washing and Waxing your Dodge Ram! Talk about it here!
Old 06-12-2013, 02:14 PM
Jim45498 Jim45498 is offline
Vehicle: 2013 Dodge Ram RCSWB
Rep:60
Jim45498 will become famous soon enough
Default Clay Bar question
Is it a good idea to clay bar a new truck?
Old 06-12-2013, 02:17 PM
arietem's Avatar
arietem arietem is offline
Vehicle: 2013 Dodge Ram 1500 4x4 QCab
Trim Level: SLT - 8spd 3.55 20"
Color: Mineral Gray Metallic Clear
Rep:368
arietem is just really nicearietem is just really nicearietem is just really nicearietem is just really nice
Hi, I've read that many have. Some have had to use the clay bar to get rid of RAIL Dust ..
Regards
KnotSerious's Avatar
KnotSerious KnotSerious is offline
Trim Level: Laramie Longhorn
Color: Deep Cherry Red/ Crystal Pearl
KnotSerious is on a distinguished road
I haven't done my truck yet, just got it last week. But I used the clay bar on the new car I got last year and it made a big difference. Took all the little bumps out of the finish and then I put on the wax and it looked great. I had started waxing before the clay bar and couldn't get a good shine, it kept showing those small bumps.
Good judgement comes from experience; Experience comes from bad judgement.
Old 06-12-2013, 02:26 PM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Depends on what shape your paint is in when you get it. If it's brand new out of the factory and hasn't been sitting on the lot I doubt it would need to be clay barred. If it's been sitting on a lot or has quite a bit of dust on it from transportation then it might need it. The best way to find out is to actually go out and inspect your paint. Look at it closely for imperfections and feel out smooth it is. If it's smooth then put a couple coats of wax on it and call it good. If not, clay bar it, polish it, then wax it. Lots of info on all that stuff in the washing and waxing section of the forum.
Old 06-12-2013, 02:33 PM
Rep:60
I think it was on the lot for about 3 weeks before I bought it.
I got it in Feb. and I have put a coat of wax on it. It is fairly smooth but not the slickness that a fly would slide on
It also sits in the garage a lot. Only put 1200 miles on it since I got it in Feb.
So I wasn't sure if it needed to be claybarred or not.
Old 06-12-2013, 02:37 PM
Rep:2026
It's really up to you then. I can't really tell you if it needs to be done or not without seeing and feeling the truck in person you know? So if you feel like putting in the time to do it, it definitely isn't a bad idea. Smoother is always better. Once you clay bar, polish and put a couple coats of wax on it, it will be as smooth as can be!
Old 06-12-2013, 02:46 PM
Rep:60
OK thanks Brandon
I have been looking at the Meguiars clay kit. I may just try it and take your advice and put a couple coats of wax on it afterwards. BTY the color is Silver
Old 06-12-2013, 03:18 PM
ss3079 ss3079 is offline
Vehicle: 2013 Ram 1500 CC 6'4
Color: Copperhead Pearl
Rep:30
ss3079 is on a distinguished road
Originally Posted by Jim45498 View Post
OK thanks Brandon
If you're going to clay it, you might want to consider putting a coat of polish on prior to your coat of wax.
2013 Ram Sport - CC, 6'4, Hemi/8 Speed
2007 Chrysler 300C, 1970 Dodge D100 (383)
Old 06-12-2013, 03:22 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
After you clay bar your truck and polish out any small scratches that were left by the clay bar, you might consider putting a good sealant on your truck before you put a couple coats of wax on it. The sealant will last a lot longer than the wax and will give you an excellent base for your wax. A good sealant will last about 6 months whereas a good wax will only last about 4-6 weeks, dependng on how much you wash your truck and on whether it sits outside or in a garage. You can always use a spray detailer after every time you wash your truck to keep it protected inbetween waxes. A lot of people use these steps: wash, clay bar, wash again, polish, seal then wax.
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected.
Semper Fi Forever
Old 06-12-2013, 04:08 PM
Rep:60
WOW!! Looks like this is going to turn into a lot of work. Hey, I'm an old man.
