Old 06-12-2013, 05:44 PM
Raminator5280's Avatar
Raminator5280 Raminator5280 is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Bighorn
Rep:56
Raminator5280 will become famous soon enough
Default Brightest bulbs?
What would be the brightest bulbs I can use without going to HID? Im looking for a simple plug and play that wouldn't cause any problems.
DiabloSport Trinity w/CMR tune, K&N FIPK, 87mm ported TB, Dynatech LT Headers, Magnaflow cats, ypipe, & muffler, Jetstream scoop, diy ram air, push start
Old 06-12-2013, 08:07 PM
Asur Asur is offline
Vehicle: .
Rep:4373
what you get with "so called bright bulbs" be careful and read the fine print, they will always indicate "40% or 50% brigter than comparable halogen bulbs" with a nice * on the end, then you look down the info page at the "*" and it says (compared to worn out halogen bulbs) so in the end, the only thing they will do is you can get bulbs that have a higher light output color, like more white of a color, a 35 watt bulb replaced by a 35 watt bulb is still going to give out 35 watss output. If your going for good Bulbs, I feel PIAA have some very good bulbs, they have always had great products, but they don't come cheap, and as in anything, you pay for what you get, also, do not put in higher wattage bulbs as replacements, some replace there current bulbs with 80watt bulbs and burn out there wiring and sockets.
here is an article about what I am saying
http://autos.yahoo.com/news/do-high-...210841757.html
Old 06-12-2013, 08:39 PM
Grubrunner's Avatar
Rep:3883
The link below is one of MANY with the same subject line.
A "search" will yield great results as this subject has been discussed more than a few times.
Good luck.
For the record, I'm also a PIAA advocate.
http://www.ramforumz.com/showthread....t=bulb+upgrade
Grub out!
Old 06-20-2013, 10:32 AM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
For the price of PIAA bulbs, you can buy 2 HID kits for fog and low beams; I doubt you'll ever need the high beams on after that. total price for me, $75. 10x better light output, well worth converting to HID, IMO
Old 06-20-2013, 04:33 PM
patricklee85's Avatar
patricklee85 patricklee85 is offline
Vehicle: 2009 Dodge Ram
Trim Level: SLT Big Horn
Color: Blue
patricklee85 is on a distinguished road
I went with some goofy bulbs with oriental writing on the package off of eBay (yeah, yeah...I know) but I've been very pleased with their performance so far. Much brighter than the factory ones I took out (which I'm sure were aged), much cleaner light with a bit of a blue hue. Can't speak for the life of them yet as I just put them in about a month ago.
They were 5900K 100W WHITE XENON.
If it works, it works.
Old 06-20-2013, 04:59 PM
Grubrunner's Avatar
Rep:3883
Really?
What brand?
Grub out!
Old 06-21-2013, 08:16 AM
Rep:66
Originally Posted by Grubrunner View Post
Really?
What brand?
I've used Innovited; they seem to make their own stuff. Another HID company out of Chicago I believe. I have bought all of these things on Amazon, so far, Zero problems other than my own fault of not using a relay on the low beams at first. I used the 4300k, beautiful light. I was not interested in looking cool, only in better light. BTW, the Fogs and low beam light colors match perfect. Here is a list of everything I used, Innovited ships FAST. I had my stuff in 2 days, everything is free shipping. Total I spent, $79.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Old 06-23-2013, 11:52 AM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
i considered HID for a long time too, but you can get the daytime running lights to work with HID, a must here in Ontario (not sure about Canada but i suspect its mandatory in all provinces/territiores).
SO, i too am a PIAA advocate.
Old 06-24-2013, 08:08 AM
Rep:66
There are several DRL Capacitor harnesses avaible to work with HID; I too was not going to switch, but after pricing PIAA bulbs, I figured what the hey, might as well try to swap them. Man, I'll NEVER go back to Halogen bulbs, ever! My 4300K fog lights are brighter than my factory bright lights. Living up here in white tail country, HID's are now a must. PIAA are great bulbs, but for the price, and darn near the same amount of work to change them, I went with HID.
Old 06-24-2013, 05:31 PM
Rep:912
good to know man..thanks..
i couldnt get any info when i was considering the switch!
maybe next time i need bulbs!
