Old 06-12-2013, 07:08 PM
ylomnstr ylomnstr is offline
ylomnstr is on a distinguished road
Default RER Radio and U Connect Microphone?
I'm looking to install the microphone on my RER radio. From what I'm seeing, there's supposed to be an empty area in the back of the radio for the microphone, but when I look at the back of my radio, all plugs are full. What am I missing here? The radio was added aftermarket, and as far as I can tell, there is no mic anywhere because when I press the uconnect button and she says to say a command, she doesn't hear anything I say or respond to anything I say. See the attached picture. Thanks.
Old 06-22-2013, 09:15 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Your radio possibly has an additional module for the bluettooth capability which is probably behnd and to the right of your glovebox. You will have to take the glove box out and look from there and the mic will plug into that module if it is the same as on my Avenger.
Old 06-22-2013, 10:10 PM
Rep:2657
i found this for the RER radio the RHR radio is done the same way
Now available for you 2011-2012 Dodge Ram (see list) owners that have upgraded to the uconnect gps (RER) mygig touchscreen radio. Now with this wiring kit you can connect your existing microphone mirror to your newly added RER mygig radio, which will enable hands-free calling, and voice control of the radio.
this member made the swap that you are making
http://www.ramforumz.com/archive/ind.../t-102254.html
If you don't have the REAR VIEW MIRROR with the dual microphones
you can run this microphone & wiring up the drivers door post & mount it there, it is the same one that they use in Jeep vehicles with your new radio
http://www.leeparts.com/dodge_ram_ds...phone_kit.html
from what i have read, the smaller GREY connector in the center is part of microphone set up
