Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 06-12-2013, 07:47 PM
Sapper's Avatar
Sapper Sapper is offline
Vehicle: 2009 Dodge Ram
Color: Blue
Sapper is on a distinguished road
Default Radio/Nav System Issue
So yesterday I replaced the battery on my truck. once I started the truck back up I realized the radio wouldnt even turn on. No ram logo, no clock, nothin. What gives?
Once more through the breach...
Old 06-12-2013, 09:48 PM
Sapper's Avatar
Color: Blue
I honestly dont know if i fried it or what and I could really use some help
Old 06-12-2013, 11:03 PM
astroman54's Avatar
astroman54 astroman54 is offline
Rep:52
astroman54 will become famous soon enough
You can try resetting it by disconnecting the battery and touching the battery cables together for a short while then reconnecting it.. You may also want to check the fuses.. There's a fuse that you pull to disconnect the radio when the truck will be sitting for an extended period of time so the radio won't draw the battery down. When you reconnected the battery there's a posibility that this fuse blew..
Andy
Andy
2009 Dodge Ram 1500 Sport Deep Water Blue Crew Cab Hemi 4x4
Old 06-13-2013, 01:45 AM
Sapper's Avatar
Color: Blue
Thanks andy, im going to have a look at it in the morning. Ill be sure to update the outcome
Old 06-13-2013, 08:24 PM
Sapper's Avatar
Color: Blue
So i pulled the battery and let it sit for a while, and i also replaced the fuse for the radio and i still got nothing on the radio.
Old 06-13-2013, 08:42 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2823
I just changed out my battery in my 2009 & i did not even lose my radio presets
so i am no help
Old 06-13-2013, 09:34 PM
astroman54's Avatar
Rep:52
Beginning to sound like the radio went out when you pulled the battery.. BTW, sounds like you didn't do anything wrong, just a bit of bad luck..
You can always take it to the dealer to diagnose.. Probably $60-80 for a half hour work to diagnose..
If it is bad, you can send it to oemautopartsco.com to fix..
Andy
Andy
Old 06-14-2013, 08:37 PM
Sapper's Avatar
Color: Blue
Ok so from what I have managed to find out is that its a theft deterrent which shuts down the radio/nav system. I called the dealership and they told me they would have to pull the radio to get the serial number so they can get the reset code. You guys think it would be possible to find it else where or be able to use my vin# to get the serial number? I have the booklet for the radio/nav and the first page has a FCC ID# which i think might be it but i am unsure.
Old 06-14-2013, 10:38 PM
astroman54's Avatar
Rep:52
I thought you said that the display on the radio is blank (black).. If it was the theft deterent, the display would be asking for the code to be put into it to activate the radio.
Also..... You have the RER radio, the anti theft code in the radio that you really need the code for was started in the 2012 year. And in that year the radio that was installed was the RHR radio, not the RER.
If it's asking for a code, try 1111 or 1234. Those are a couple of the standard codes used in the radios prior to 2012 which the RER probably would use.
If the radio has a totally blank screen, then I don't believe the code is your problem.
Andy
Andy
Old 06-14-2013, 11:50 PM
Sapper's Avatar
Color: Blue
Well shit...looks like im headed to the dealer
