Old 09-17-2013, 06:16 PM
Zixxer Zixxer is offline
Vehicle: 2013 Ram 1500 Sport
Rep:35
Zixxer is on a distinguished road
I think the key to any separation in test fitting first so you know exactly how the flares will be positioned. I cleaned my fenders with alcohol to ensure the surface was free of wax, grease, dirt. The double sided tape was actually still in good shape on my set so I carefully looked each one over and applied a thin bead of black molding adhesive. Put them in place, set the screws on the inner well areas and applied painters tape to the outer edge of the flares to ensure good adhesion while the adhesive setup. Waited about four hours, removed the tape and haven't had an issue in seven months. There is a gap on one of them towards the bottom front rear, but no one but me can see it. It also doesn't have any tape in that area, about two inches long, and honestly I worked with it awhile, but realize there's something probably off on the flare itself. I've also seen some gaps on the bottoms of some at the dealership so it's all good.
2" Mopar Lift/285/65/20 BFGs/DB Corsa Exhaust/Mopar flares/Lo Pro Tonneau/Line-X Premium/Ez Down tailgate/Catch-Can/Moe's 87mm TB
Side Molding/345 Emblems/Husky Splash Guards/Honeycomb Grill/25% Tint/Silver Rally Stripes/Crux Rear Camera and VIM
Removed - Air Grabber - filtering is not very good
Old 09-17-2013, 07:48 PM
cb1's Avatar
cb1 cb1 is offline
Vehicle: 2014 Dodge Ram 1500 4X4
Trim Level: Sport Crew Cab 6'-4"
Color: Bright Silver Metalic
Rep:15
cb1 is on a distinguished road
Thanks for the info Zixxer! I can't wait to get my truck, hopefully in 6-8 weeks...?
Toyo AT2 Extreme 295/65R20, Bilstien 5100 Front Shocks Leveled @ 2.1", 2500 Factory Fender Flares, Husky Mud Flaps, Husky X-Act Fit Floor Liners (Front & Back), MBRP Pro Series Exhast, K&N Drop In Filter & Morimoto HID Lighting
