Old 06-12-2013, 09:08 PM
Lebrun186's Avatar
Lebrun186 Lebrun186 is offline
Vehicle: 2013 RCSB EXPRESS
Trim Level: EXPRESS
Color: WHITE
Rep:31
Lebrun186 is on a distinguished road
Default Plasti dip factory 20s
Thinking of plasti dipping my alloy 20s black, any feedback or pics?
'13 WHITE EXPRESS. 20% TINT. DEBADGED. SMOKED TAILS. PLASTI-DIPPED EMBLEMS. LED INTERIOR/ EXTERIOR LIGHTS. AIRAID SYNTHAMAX CAI. 14" MUFFLEX. LOPRO TONNEAU. 4.5 INCH SPINDLE LIFT. 35X12.5X20 FEDERAL COURAGIA M/T'S. 20X9 RED DIRT ROAD BLACK & MACHINED RD01S.
Old 06-12-2013, 10:09 PM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
I plasti dipped my wheels a few months ago. Used about 3 or 4 cans. Looked really good, but i eventually got tired of it and peeled it off. Had it on there for over a month and no issues at all. Here is the thread I did on them. http://ramforumz.com/showthread.php?t=139611
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched - Rear level - 22'' SRT-10 reps on 305/45/22 nitto 420s -AMP Power Steps - Custom retro headlights
Old 06-12-2013, 11:49 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I did mine about 2 months ago. Have had to touch them up hear and there, but over all, the plati dip has been very durable. Gave my truck a whole new look.
Old 06-13-2013, 05:39 AM
arietem's Avatar
arietem arietem is offline
Vehicle: 2013 Dodge Ram 1500 4x4 QCab
Trim Level: SLT - 8spd 3.55 20"
Color: Mineral Gray Metallic Clear
Rep:368
arietem is just really nicearietem is just really nicearietem is just really nicearietem is just really nice
Smile PlastiDip Silver Metalizer on GunMetal Gray
Hi, planning on the same .. going to see if I can do the Silver Metalizer Enhancer on GunMetal Gray ... I've seen the Silver on Black .. looks great ..
For those that have done it .. what process did you use to make it easy for cleanup around the rubber tire ? did you just use masking tape ? after what #spray coat did you remove the tape ?
What prep process did you use to prepare the surface of the rim ?
I plan to do mine while the rim/tire is still on the truck.
I'll post photos when I do it.
Regards
Old 06-13-2013, 06:16 AM
arietem's Avatar
Rep:368
Hi, just went online to www.dipyourcar.com .. they have 3 new metalizers .. no base coat required .. I'm looking into the Anthracite Grey Metallic
Regards
Old 06-13-2013, 09:32 AM
Rep:2929
Originally Posted by arietem View Post
Hi, planning on the same .. going to see if I can do the Silver Metalizer Enhancer on GunMetal Gray ... I've seen the Silver on Black .. looks great .. It will look awesome and change the appearance of your truck
For those that have done it .. what process did you use to make it easy for cleanup around the rubber tire ? did you just use masking tape ? after what #spray coat did you remove the tape ? I didn't use masking tape, I just sprayed and peeled it off the tire. Came off pretty easy.
What prep process did you use to prepare the surface of the rim ? I used dawn to wash the wheels thoroughly, then I used electrical contact cleaner, sprayed the surface and let dry.
I plan to do mine while the rim/tire is still on the truck. That's how I did it. I did jack the truck up and took the lug nuts off 1) so I could get all the way in to the lug well and not get the lug and 2) so I could rotate the tire for 360 degree coverage.
Looking forward for them. Have fun! You won't regret it.
Last edited by RogerRamJet; 06-13-2013 at 09:35 AM. Reason: brain working faster than fingers
Old 06-18-2013, 03:54 PM
nfd538's Avatar
nfd538 nfd538 is offline
Vehicle: 2012 sport crew
Trim Level: sport crew
Rep:16
nfd538 is on a distinguished road
Mine has been on for about a month with no issues.
Process: cleaned wheels with window cleaner, did about 4 or 5 coats per wheel, no tape and didn't even peel excess off tires. I also did the inside of wheels.
BT catch can, 20% tint, Leer 100xl top, Aero 3030xl
Bilstein 5100, Duratracs 275x65x20 (winter), 20" SRT & 275x55x20 Nitto terra graps (summer), InTune DCX, MagHytech diff coverhttp://i29.photobucket.com/albums/c2...pstcriuhl7.jpg
Old 06-19-2013, 09:45 PM
Northman11 Northman11 is offline
Vehicle: 2012 Black Sport CC
Northman11 is on a distinguished road
I did mine about three months ago and they looked great at the time (black 1500 crew cab sport). Now, it is starting to separate between the wheel and tire. Touching up those areas just made it look worse. I'm tempted to remove it and try it again though. I love the black on black look but I didn't want to drop the money on new wheels just yet.
To echo what nfd538 said, do really light coats at first. It will look like a slight haze for the first few coats. Just keep repeating it and it will work just fine. I took a garbage back, cut it in half to open it up as a single layer, and inserted it into slots in the wheel to wrap up the brakes. That way, the plastidip stayed on the outside without hitting the brakes.
