Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Dodge Ram Decals
Old 06-12-2013, 11:45 PM
aktrite28's Avatar
aktrite28 aktrite28 is offline
Vehicle: 2009 Dodge Ram 1500 SLT Hemi
Trim Level: Slt big horn
Color: Blue
aktrite28 is on a distinguished road
Default Help with blend door actuator location/replacement
Hey guys and gals,
I am in need of replacing an annoying knocking blend door actuator, dealer is charging me nearly $800 to replace part was only $50 so the rest was labor!
I have found 3 actuators so far (located lower part of dash behing faceplate assembly none of wich need replacing and the one knocking seems to be behind some more plastic. Does anyone know how many total this truck comes with? Any experience replacing this part what needs to be removed for access? I dont want to remove the whole dash assembly just to find out all i had to do is remove screws! lol
i am no mechanic but i am a do it yourselfer and as an unemployed student have more time then money!!!
thanks
ps. i tried downloading the service manual link with no luck!
Old 06-12-2013, 11:54 PM
SnakeBoot SnakeBoot is offline
Vehicle: 2009 dodge ram
Color: red
SnakeBoot is on a distinguished road
Default I feel your pain !!!!!!!!!!
Going thru the same B.S Bud.!! I couldn't get the manual download either.?? Bad Link. Keep trying , someone in the forum will step up sooner or later.
Old 06-13-2013, 02:55 AM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2875
you best do your research
in 2009 they knew the Climate Control was fuc* from the get go
i have been drinking & i am not going to look up the
RRT, etc.
but there were everything but recalls about this subject
Old 06-13-2013, 09:01 AM
Asur Asur is offline
Vehicle: .
Rep:4373
RRT, etc.
Reps for that answer
Old 06-14-2013, 01:37 AM
aktrite28's Avatar
Color: Blue
ok well thanks for that 411. Yes i have found plenty people with the same issue, i already know what it needs just looking for some direction as far as which way to go when disassembling my dash. I guess im gonna try the haynes see if that has anything good. Thanks
Old 06-14-2013, 11:44 PM
rarichard's Avatar
rarichard rarichard is offline
Vehicle: 2010 HEMI Sport Crew Cab
Trim Level: SPORT
Rep:62
rarichard will become famous soon enough
when mine was done under RRT, I didn't hear anything and told them I didn't want them to open it up until it starts to be a problem cause I didn't want any loose dash pieces making noise when put back together. She said it was an easy fix under the glove box area or only required removing the lower panel or something. They ended up fixing it and I couldn't tell where they went in.
Old 06-15-2013, 10:01 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:251
Ramzaq is a jewel in the roughRamzaq is a jewel in the roughRamzaq is a jewel in the rough
Info is on here, just have to look around, maybe do a search. From my old post.
For those out of warranty and like to fix your own things, here is a quick guide for that clicking noise.
Chances are it is only the motor that is bad if it is clicking or thumping.
Not very hard to fix really. I think most of these cases are the motor gears stripping and not the doors themselves.
If you know how to take the center stack bezel around the radio off you are halfway there. Don't forget about the screw over the 115V out let. Take the bezel off then the two side 12V acc. plugs. Remove the ring bezel around the cup holder if equipped.
The culprit is the lower center motor, unplug remove two screws and remove.
If the gears are stripped you can position the big gear 180 out from the smaller gear. The door only travels about 120 degrees so won't hit the stripped part.
Reassemble and you should be good to go. 1 to 2 hours of your time. If you want to get a new motor it is about $40 from Chrysler.
Hopefully this is the extent of your problem.
Attached Images P8210400.jpg (89.2 KB, 28 views) P8210401.jpg (95.7 KB, 28 views) P8210402.jpg (82.0 KB, 26 views) P8210403.jpg (117.5 KB, 30 views) P8210404.jpg (119.0 KB, 27 views) P8210405.jpg (122.5 KB, 29 views) P8210406.jpg (124.4 KB, 32 views) P8210407.jpg (119.9 KB, 33 views) P8210408.jpg (103.7 KB, 34 views) P8210409.jpg (55.7 KB, 34 views)
Old 06-16-2013, 01:13 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
nice! i love this forum. i will be fixing mine tomorrow! im in warranty, but i can do this for free (rotate it) and it saves me a 20 mile trip one way.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 06-16-2013, 02:58 PM
Rep:2875
Removing the radio bezel is simple & you can see almost everything under the dash
Old 06-19-2013, 01:14 AM
chadob69's Avatar
chadob69 chadob69 is offline
Vehicle: 2009 Dodge Ram 2WD
Color: Blue
chadob69 is on a distinguished road
I had the same issue. I pulled the radio bezel out and the glove box. Once i had all that out, i turned the ignition on to see which actuator it was. It was the recirculation door, the one on the far right. I did some research and their is a recall on all of those actuators. I took the truck in (not under warranty) and the dealer replaced all 3 actuators at 0 cost.
