Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Place your Ad Here!
Old 06-13-2013, 04:27 PM
DAA DAA is offline
Vehicle: 2013 1500, CC/6'4", Hemi/8 spd
Trim Level: Longhorn
Rep:352
DAA is just really niceDAA is just really niceDAA is just really niceDAA is just really nice
Default Air bags with no load?
So, I've got a '13 1500 on order, but not here yet.
Going to put air bags on the rear to help with times the bed is loaded or a lot of tongue weight.
Trying to figure out which air bags are going to work best for regular daily driving with no load in the bed. I mean, the reason I'm getting a coil sprung 1500 is for the cushy ride when empty. So I don't want to mess up that sweet smooth factory ride.
Looking at TLC and Air Lift 1000. Also looked at Firestone Coil-Rite, but I think I like the Air Lift better for inside the coil.
Right now, I think the Air Lift 1000 is looking like the best setup for not having any effect on the factory ride when the truck is empty and the air bags only have 5 psi in them. Have read a bunch of reviews and posts on them and haven't seen anyone complaining about the Air Lift bags affecting the factory ride with 5 psi in them.
Looking at the posts and reviews on the TLC bags, most guys seem to really like them, but there are also a decent number of reviews complaining about the way they affect the factory ride. Just going by what I've read so far, it sounds like they ride pretty good with only 2 or 3 psi in them, but that they are annoying with the way the tops slam and slap the empty bump stop cup on the frame. With 5 psi, they don't make annoying noises anymore but give the truck a 2" lift in the rear (when empty) and make for a bumpy ride.
Anyway... I'd really like to get as many opinions from guys that have them as I can.
So what say you? What system are you running and can you even tell it's there when the truck is empty? Good/Bad/Ugly? Happy? Regrets?
Thanks!
- DAA
Old 06-13-2013, 04:51 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
I've read the exact same things you just explained in your post. If you don't want any effect to the factory ride quality when unloaded the Airlift 1000's are the way to go. Otherwise TLC does seem to be lifting the back of the truck from stock height which is a major downside IMO.
I've been running the Airlift 1000's for about 4 months now. When not loaded I run the recommended 5 psi in them and you can't even tell they're there. Ride is just as comfortable as stock. Then when loaded I bump up the psi as needed. They definitely help a ton with leveling out the truck and stabilizing the load. Without them my truck was bouncing up and down like crazy when towing. Now with them it keeps it very smooth and rides very nice.
Old 06-13-2013, 10:17 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
Although I can't comment on the TLC set up, I am new with the airlift 1000 and they really are an excellent "bang for the buck" set up. Very easy to install, I used an exacto-knife for cutting the airlines to length and a simple pair of pliers to tighten the nuts for the shrader valves onto the rubber grommet for wherever you mount the fill points. Lots of good reviews for this setup, that's why it was a confident choice to buy these.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ EFI LIVE 75 HP TOWING TUNE/ OD TUNE
Old 06-13-2013, 11:35 PM
highlandchef's Avatar
Trim Level: SLT Big Horn
Rep:220
I've had the Airlift for about 18 months with no problem. When unloaded I run the recommended 3 - 5 psi (so they don't get pinched by the coil) and I don't think that affects the ride at all. Highly recommend the Airlifts; good bang-for-the-buck.
Old 06-14-2013, 12:14 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:418
There have been plenty of times I've gone to the mountains and unhooked my trailer and forgotten to let the air out of my Airlifts. Never noticed that I had not deflated. The things are awesome. For $90 how can you go wrong.
Old 06-14-2013, 07:19 AM
DAA DAA is offline
Rep:352
Thanks for the feedback guys.
Really sounds like the Air Lift setup is the way I should go.
Now if my truck would just get here before summer is gone...
- DAA
Old 07-25-2013, 08:38 PM
birdboy birdboy is offline
Vehicle: 2010 ram 3500
birdboy is on a distinguished road
i run 5 lbs when empty,all good
Old 07-29-2013, 08:16 PM
MrPiper's Avatar
MrPiper MrPiper is offline
Vehicle: 2012 Ram 1500 Bighorn
Trim Level: 1500 Bighorn
Rep:54
MrPiper will become famous soon enough
I have Airlift 1000 and have been very pleased for over a year and over 8,000 miles towing a trailer that weighs around 7,000 lbs. I ran the air nipple through the hole that is already there beside the hitch and air it up with a cheap $20.00 cigarette lighter emergency pump that I keep in the truck anyway just in case of a flat.
I run 5 lbs. when not towing and the ride is, in fact, the same as before the install.
I am NOT a mechanic by any stretch and this install took less than 2 hours in my driveway.
Finally, the payload for my 2012 Bighorn 1500 crew is 1630 lbs. To buy a air bag system that can accommodate 3 to 5,000 lbs. seems like significant overkill to me and the $90.00 price tag is unbeatable.
Old 07-29-2013, 09:08 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I also just bought the airlift setup and like it so far. I just put 2,250lb in the bed of my truck today and it handled it well. Still a lot of squat but was very firm and under control. I'm sure with a normal load it wouldn't have squatted so much.
Sean
Old 08-11-2013, 02:51 PM
DAA DAA is offline
Rep:352
Still don't have my truck (it finally got here yesterday, but has damage that needs repair). But have the Airlift bags and WirelessOne controller/compressor kit just waiting to be installed. Sold my uninstalled TLC kit. Getting my truck a week from Thurs, so the big install day will be that Saturday - two weeks from yesterday. Have sitting here Bilsteins four all four corners, air bag system, separate high volume 100% duty cycle onboard air system, cabin air filter, also a Blue Ox WDH to setup and of course will have new tires put on before even bringing the truck home. If everything goes smooth and I have time, will probably debadge the beast to finish off the session - those huge Longhorn badges on the doors have got to go...
Ought to feel good when I finally get the truck and get all the stuff installed and crack a cold one that Saturday afternoon - after the test drive, of course . Then I plan on putting a few hundred miles on it the next day to break it in, change the oil, then towing the travel trailer up into the mountains the following weekend.
Going to get there eventually!
- DAA
