Old 06-18-2013, 05:07 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Originally Posted by macc08 View Post
dont say that! lol
what kind of offset would be required on an aftermarket wheel to prevent the use of spacers? and whats the factory offset?
0 you can clear. most go negative to get a good stance.
factory is +19
Old 06-18-2013, 05:14 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
dont say that! lol
factory is +19
Correct, 20x9 0 offset will give you the least chance of rubbing. You'll be sticking out about 1 5/8" on the front with 35x12.5's. I personally went with a 20x9 -12 offset wheel to get a little wider of a stance, especially for when I lift it. I stick out 2 1/8" on the front with my set up (I think you saw my wheel/tire thread with all the specs)
Old 06-18-2013, 05:35 PM
macc08's Avatar
macc08 macc08 is offline
Rep:722
i would indeed want to have them stick out a bit, just not sure about how far. I still dont know much about tires and wheels... can you get wheels in pretty much any offset? or does each manufacturer have their own offsets that they offer wheels in?
Old 06-18-2013, 06:11 PM
Rep:2036
Generally you can get most wheels in a variety of different offsets. Some manufacturers and models will vary slightly, but you should be able to find a set up that works.
Old 06-21-2013, 12:39 PM
macc08's Avatar
Rep:722
cool, thanks!
as i said before, i really appreciate the help! everyone here seems so helpful, and its awesome!!!
im heading to my buddies shop (overdrive Auto) tomorrow for a shop BBQ and sale, etc. hopefully gonna order my levelling kit and look into some tires/wheels, im losing sleep over it cause I'm so excited!
Old 06-21-2013, 11:37 PM
Troyw740's Avatar
Troyw740 Troyw740 is offline
Vehicle: 2005 dodge Ram 1500 5.7hemi 4x
Color: light almond pearl
Rep:16
Troyw740 is on a distinguished road
I have a 2004 dodge ram 1500 3.7l v6 rwd I have a 3"rc suspension kit and a 2.5 coil spring leveling kit. Will these go together with little alignment issue and the brake line be long enough also. And if I have issue could I adjust my tires rod ends to compromise that . Anybody know this would be helpful. And also will the RC 3" front shocks gonna be long enough with the 2.5 level coil spacer on top? Tried installing it today in 3hrs got drivers side amost done and the shock top nut was seized on I'm gonna have to cut it off clean.
Old 06-23-2013, 04:47 PM
macc08's Avatar
Rep:722
you can drop to a 17" at the smallest!
it still looks good man! I love more tire less wheel.
here are some pics:
soooo ive been looking at a 17" setup, and i like it!
saves quite a bit of money too, so i think i may go that route!
Old 08-27-2013, 10:36 PM
OfcrFr's Avatar
OfcrFr OfcrFr is offline
Trim Level: SLT Big Horn
Rep:27
OfcrFr is on a distinguished road
how am i just finding this section?!
DD and Tow Pig lol-2007 Ram, HEMI, Big Horn, 3.92 gears (open dif) 295/60/20 Nitto Trail Graps, Bilstein 5100s maxed, 18 inch Magnaflow SI/SO with 4 inch tip, Mods added all the time.
Old 08-28-2013, 08:44 AM
Rep:1900
It was made along with this sticky not too long along. It hasn't been around long
Old 09-03-2013, 08:27 PM
mortician79 mortician79 is offline
Vehicle: 2011 Dodge Ram 2500 HEMI
mortician79 is on a distinguished road
Greetings all!
I have a 2011 Ram 2500 Hemi Crew Cab 4X4. I installed a 2" Hell Bent Steel front leveling kit a few months back. I plow with this rig, I wanted it to level out a bit. Immediately I heard a noise coming from the front end. It sounds like someone tapping on a drum. It usually happens when there is deflection in the road or turning, potentially in the steering somewhere. Any ideas on what is causing this noise?
