Old 02-18-2014, 06:14 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Just take a look at the suspension. It will be somewhat hard to see but it is possible. If there's a spacer on top of your strut it's leveled. But it will be tucked up in the strut tower so it is hard to tell.... Or if it has Bilsteins it is probably leveled.
You can take measurements from the ground to the top of your wheel well though. If it's stock there will be about 2.5"-3.25" difference front to back. If there's less it probably has a leveling kit.
Old 02-18-2014, 07:12 PM
chrisnarron chrisnarron is offline
Vehicle: 2009 dodge ram 1500
Color: gray
Rep:59
chrisnarron will become famous soon enough
Ok. I know there is definently a spacer. Just dont know what size. So as long as im level can I run 295/65r/20? Do I need a spacer? Thanks so much.
Old 02-18-2014, 07:14 PM
Rep:2026
Ya if you're leveled you should be able to run that height no problem. You're keeping stock rims I'm assuming? Typically the widest you can go on stock rims is 285. There are guys that get away with wider but it's not a guarantee. So I'd have a set of 1/4" wheel spacers ready just in case you do need them. You can always return them if you don't.
Old 04-04-2014, 08:16 PM
chadlee70 chadlee70 is offline
Vehicle: 2003 dodge ram 1500
chadlee70 is on a distinguished road
Default After market wheel back spacing and leveling kit
Ok I am pretty new to this I have a 2003 ram 4x4 1500 and I ordered a leveling kit and a set of wheels ion 187 17x9" and the back spacing is +18mm or 5.71" my question is I have a set of used 315x70x17 tires I want to put on it after leveling and was wondering if that back spacing will work or if I will need to get wheel spacers? If so should I try to get hub centric and what size, everything else is factory including shocks because kit came w shock extender mounts the wheel Hub bore is 78.8mm I believe and the rims center bore is 108mm any opinions would be greatly appreciated and if I am reinvinting the wheel sorry
Old 04-07-2014, 01:23 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
you'll need spacers with that wide a tire and +18 offset. what leveling kit did U order? 2003 have torsion bars. different from the 06-08 3rd gens
Old 05-29-2014, 02:15 PM
SoCalExpress SoCalExpress is offline
Vehicle: 2013 Express Quad Cab
Trim Level: Express QC Rwd
Color: Mineral Gray
Rep:108
SoCalExpress will become famous soon enoughSoCalExpress will become famous soon enough
Guys have any recommendations for a 2013 QC 2wd leveling kit? I put on some 275 65r20 Goodyear AT's and the wheel well looks too stuffed, no rubbing though. I was hoping to use a heavy duty coil over to get the extra height in the front but am having terrible luck finding anything. If I get spacers, any recommendations? Also should I replace the shocks too? Recommendations on those?
Thanks for your help, not the heat when it comes to wheels and suspension.
Custom Header Back SS true Dual Exhaust with 2 22" Maggys, De-Badged sides and blacked out tailgate emblem, Tonno Pro tri fold cover, Fold forward rear seat (extra storage is great!)
Pictures - http://s1090.photobucket.com/user/pa.../library/Truck
