Old 06-20-2013, 07:34 AM
98rumblebee's Avatar
98rumblebee 98rumblebee is offline
Vehicle: 1998 Dodge Ram 1500
Color: Yellow + Black
98rumblebee is on a distinguished road
Yeah I'm gonna replace them. But the part that confuses me is that the vacuum on the black line does not change between 2H and 4H. This leads me to believe that the red one is responsible for engaging the axle. And yet this was not the case for your truck?
Put a good dip in
Old 06-21-2013, 11:22 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
They both supply vacuum. One engages the other disengages. Almost like a negative vacuum, but not quite. Check the vacuum at the TFC and see if it's working there. If you have a hand vacuum pump you can test the line to the front with that.
If you have a few feet of vacuum line (even some old air shock line but something that won't collapse, brake line etc...) you can trace it from the transfer case (driver's side) and solve the issue if there is a leak.
