Old 06-14-2013, 10:15 AM
weswisehart weswisehart is offline
Vehicle: 1996 dodge ram
Color: blue
weswisehart is on a distinguished road
Default 96 dodge 5.9 wont start has fuel and spark.
I have a 96 Dodge ram 1500 5.9 4x4 automatic. I recently swapped in a new transmission and now the truck won't start. I get 50 psi at fuel rail and spark to the plugs. I'm getting good compression as Well. When I pull the fuel rail to watch the injectors the spray fine but only long enough to get spark then they shut off. I've replaced the rotor cap the pick up, plugs , wires, rotor button, tps, crank position sensor, and the valve on the rear of the throttle body. I'm at a loss. Thanks for any info.
Old 06-14-2013, 11:09 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Pull the dipstick and see if you can set it on fire. If it'll burn, you'll need to clear the engine, to do this, 1st, make sure you are getting full throttle from the pedal, (most of us don't, until we do the ziptie at the gas pedal trick.) Once you know you are getting full throttle, hold her to the rugs and turn it over . Full throttle in start mode shuts the fuel off, it's called clear engine mode. If your dipstick won't burn, I dunno, at least it isn't flooded! Also, you may want to reboot the ecu. key to ign, disconnect NEG cable from battery, key off, reconnect battery.
Old 06-14-2013, 11:25 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
^if that fails^
Did you check around the bell housing for a pinched wire?
I know this is improbable because it's cranking but the neutral safety switch wiring?
Also check the wiring to the starter and make sure the power and trigger wire are okay.
Old 06-15-2013, 12:18 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
^And if that fails^
Sounds like you maybe have the throttle cable and the kick down cable reversed. Yeah, I don't know how either, but somehow, your throttle cable is at WOT which is why you're not getting any gas. Let us know what happens. Good luck!
Old 06-19-2013, 08:44 AM
Color: blue
Thanks for the input I will check the throttle cable and report back. I have reset the computer another ten times ha ha
Old 06-19-2013, 03:28 PM
Color: blue
Well I pulled all of cables and that did No good ran for five seconds and died tried 5 times and did the same all 5 times
Old 06-19-2013, 04:03 PM
Vehicle: 95
Rep:1776
Do you think that it may be unrelated and just bad timing?
Try having someone start it while you rap on the tank with a rubber mallet.
I just thought in your OP you had fuel so now I'm confused at that the symptoms really are. Did we get side tracked?
Old 06-19-2013, 05:18 PM
Color: blue
The timing is dead on I hit it with a light. The fuel pump is working it comes on I hear it and tested the rails. I'm Also getting spark. But only for a bit.
Old 06-19-2013, 05:48 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:221
Isn't there some kind of inducter type set up for the ignition on the vintage truck?? Just shooting in the dark, but could that be bad?
Old 06-20-2013, 11:03 AM
Vehicle: 95
Rep:1776
I wasn't referring to engine timing. I was referring to bad timing as in not at a good time, hence implying that it was an unrelated issue...possibly.
Have you checked the crank position sensor. I just feel like we got completely off track here and everyone is just guessing...maybe there's low air in the tire.
