Old 06-14-2013, 04:18 PM
StuderCo StuderCo is offline
Trim Level: Sport Quad Cab
Rep:24
StuderCo is on a distinguished road
Question Do I NEED Grille Inserts?
I have a black '13 Sport. Obviously it has those three horizontal chrome grille inserts in all four "holes". I was going to plasti dip them, but they actually stick out much further forward than I want.
So can I just remove them and drive without them?? What's the risk? Do I NEED a set of black inserts or something? Tell me what you know. Thanks.
2013 Ram 1500 Sport Quad Cab
14" Magnaflow, Full Tint, Stubby Antenna, Cabin Air Filter, PE Jackrabbit
2007 F-350 Lariat 6.0 FX4 Crew Cab - SOLD
Studs, Gaskets, EGR del, 4" Turboback, SCT X3 w/ SPD, PHP Hercules 100, 4.5" lift, S&B Intake, Coolant Filter, Black Bumpers, 35x12.5x20", Smoked Lights, 6000k HID's
Old 06-14-2013, 04:20 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2051
Nope, you don't need them at all. They're just for looks as far as I know. The one thing I could see is that they offer some protection from big objects flying into your radiator. But I wouldn't worry too much about that.
Old 06-14-2013, 04:21 PM
Rep:24
Yeah that's exactly what I was thinking. Last thing I need is a 1" stone flying into my radiator on the highway. Is there any other protection for the radiator further behind the grille inserts?
Old 06-14-2013, 04:33 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I don't know but is it possible to turn them inside out? Just a thought.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 06-14-2013, 04:34 PM
Rep:24
I'm pretty sure they're curved with the face of the grille, so this wouldn't work so well.
Old 06-14-2013, 04:36 PM
Rep:2051
Not that I know of.
You could get the OEM honeycomb grille. That one doesn't stick out as far. Otherwise an aftermarket mesh grille would work as well.
Old 06-14-2013, 11:12 PM
Rep:24
Yeah, I know I could buy another part for it. Was trying to do this as inexpensively as possible.
Also...found out the hard way with my truck half apart, that you do kind of need the grille inserts. See, the two air dams behind the grille don't actually attach directly to the grille. They attach to the grille inserts, which then attach to the grille. Without the inserts, the air dams have nothing to attach to, and you'll see your whole rad and everything through the grille (which looks dumb).
So...does anyone have some good insert options for me? Where can I get them? I would prefer a dark black mesh (something that's not really visible, just a blacked out area). As cheap as possible please. If you have a part number...even better. The honeycomb inserts would suffice, but I'm not a huge fan of them.
Thanks!
