Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 06-15-2013, 08:28 PM
Dhamlin Dhamlin is offline
Vehicle: 99 dodge ram 3500 cummins
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
Dhamlin is on a distinguished road
Angry A/C issues on 99 Ram 3500 cummins
A/C line had leak fixed it recharged system but not cooling?? While It was charging compressor was kicking on & off. But had another leak fixed it but still not cooling??? Any ideas? Black quad cab cummins, AZ summer, NO A/C= ME NOT HAPPY!
Old 06-16-2013, 09:50 AM
JWM59's Avatar
JWM59 JWM59 is offline
Vehicle: 2013 Dodg Ram
Rep:148
JWM59 will become famous soon enoughJWM59 will become famous soon enough
My 96 had a bad condenser. They were known to corrode and leak.
Old 06-16-2013, 05:03 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Once you compromise the integrity of the system, at minimum for it to work, you'll have to vacuum the system to like negative 30 lbs. (it also gets out any moisture) and then refill it. The negative reading should hold steady for 5-10 minutes to show there's no leak in the system.
With the system at negative pressure it will suck in the new refrigerant.
