Old 06-16-2013, 01:25 AM
775carguy 775carguy is offline
Vehicle: 2002 Dodge Ram 1500
Color: Charcoal
775carguy is on a distinguished road
Default 2002 1500 quad cab Front end rattles
So i am new here but not new to the Dodge or truck seen in general. I have had my Ram since 2003 and I love it. It is a bit of a pig as far as fuel mileage but it is tough as nails. Recently When going over cracks or small bumps in the road I get a rattle noise that is really kind of loud.It goes away almost as fast as it comes but it is consistant. I climbed under it today and checked for anything lose and saw nor felt anything. The only thing that had movement was the axle shafts on the front IFS. Im kind of stumped. The shocks are aftermarket and new so they dont have anything to hit. After having her for so long i know every creak and groan but this is frustrating. Any ideas?
Old 06-16-2013, 09:57 AM
DarthRam's Avatar
DarthRam DarthRam is offline
Join the Dark Ram Side!
Rep:1534
Does it make the sound when only going over rough ground? Did you check the non-mechanicals? Hood, grill, and bumper bolts? Also, you said the shocks are new. Did you put them in or did a shop? Check the bolts on those or mounting points.
Magnaflow 14" Custom Install Bilstein 5100s Front Only Set at 2.8" Vararam Air Grabber Cravenspeed Stubby Antenna Dee Zee Tailgate Assist Billet Technology "The Punisher" Shift Knob Debadged doors and tailgate Plasti Dipped HEMI Badge The Punisher Grille and Tailgate Badges Exterior Chrome Delete 20" XD Series 795 Hoss LT305/55R20 Nitto Trail Grappler M/T Cabin Air Filter BAKFlip Roll-X Tonneau Cover
Old 06-16-2013, 10:15 AM
Stusmobile Stusmobile is offline
Vehicle: 2013 Quad Cab
Rep:98
Stusmobile will become famous soon enough
Check your cat converter too, the outer cover can break free of it's welds and rotates around the actual cat. Makes more of a tinny rattle than a suspension problem and is a quick and easy fix as long as you have access to a welder.
