Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 06-16-2013, 02:20 PM
Cowboy's Avatar
Cowboy Cowboy is offline
Vehicle: 2015 Ram 1500
Trim Level: Express Quad 4x4
Color: Maximum Steel
Rep:14
Cowboy is on a distinguished road
Default Spark Plug Location
Ok, so this may be a stupid question, but where exactly are the plugs located on an '09 4.7? Quick look reveals plug wires going to a row of plugs residing just below the valve covers. Where is the 2nd row?
2015 Dodge Ram 1500 Express, 5.7 Hemi, 4x4, Maximum Steel, Quad Cab
Old 06-17-2013, 12:01 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
You have individual coil packs. Look for the wires going to the coil packs. Under the coil packs, on either side of your intake, are the plugs.
Old 06-17-2013, 10:11 PM
Cowboy's Avatar
Rep:14
Awesome! Thank you! Going to knock the plugs out. Then just need to work the tricks to knock out the rear plugs on the lower bank. Not going to spend $300 to have the dealership do 'em. Although it could save me some time and frustration...
Old 06-17-2013, 10:28 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
it's not that hard. my ram was my first plug change ever, took 2 hours. remove the driver side wheel and inner fender, makes gettig to the plug by the booster easier
if it's the same for the 4.7, not sure. mines the hemi
Old 06-17-2013, 10:33 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Hey there. Your engine has an upper and lower bank of plugs(16 plugs total, 2 per cylinder). The upper bank is located directly under the coil packs(no plug wires). The lower bank is located in a more "typical" location, near the exhaust manifold, and have short plug wires coming from the same coil packs. So each cylinder has one coil, and 2 plugs. The upper bank are supposed to be changed every ~50k miles, the lower bank every ~100k miles. Both should be replaced with the EXACT same plugs as oem(and they are different for upper and lower banks). Part numbers are in the manual. Using other plugs can cause big issues. I know one other guy using other than oem plugs on this engine and we spent A LOT of time figuring out the best plug for his situation(he's heavily modified....spraying nitrous).
I just did my upper bank plugs at ~70k miles. Honestly they weren't in that bad of shape. Most of the boots under the coils ripped in half. What a PITA. But after figuring out how to proceed it was fairly easy. I ended up replacing every coil(you can't buy the boots separately) and I kept the original coils as extras. I bought them from autozone for ~$20/ea which is pretty cheap. I think the dealer wanted closer to $30/ea which is still pretty cheap.
They rip because there wasn't enough dielectric grease and the rubber fused to the plugs. I spent about 3 hours on the first plug trying to get the boot off. I finally found another guy online that had the same problem and used his solution. I took a piece of copper tube(plumbing) about 8" long, I think 3/8" might be 1/2" though. It will fit between the plugs and boot(after it's ripped in half) and separate the rubber boot from the plug. Then you can easily remove the boot, then the plug.
I put a SH*T ton of grease on the new ones, and intent to regrease them once a year, so they don't tear next time.
Any questions PM me. Also, I wouldn't do them all at once, do them in sequence. The bolts for the coils are also the bolts for the intake manifold, so removing them all at once leaves the manifold loose.
Sean
Old 06-17-2013, 10:34 PM
snrusnak's Avatar
Rep:1388
gonefishin, FYI, your hemi also has 16 spark plugs. If you only change 8 you have 8 more to do!
Sean
Old 06-18-2013, 10:22 PM
Cowboy's Avatar
Rep:14
thanks for the heads up snrusnak. i've heard about the boots ripping. that's probably my biggest hesitation. at that point it'd only save a little more cash doing it myself than taking it to the dealership. is it really that common for the boots to rip? guess i better make sure autozone has the boots in stock. doh!
Old 06-18-2013, 10:28 PM
snrusnak's Avatar
Rep:1388
They don't sell the boots separate, you have to buy the entire coil.
How many miles are on the truck? I'd still do them yourself, that way you know how and can grease them every so often so you don't rip them next time(they will still charge you for the coils if they rip them, FYI).
Sean
