Old 06-17-2013, 09:21 PM
MidnightHemi's Avatar
MidnightHemi MidnightHemi is offline
Vehicle: 2004 Dodge Ram 2500 4X4
MidnightHemi is on a distinguished road
On the inertia side what would you recommend? The spartan?
87mm Moes TB,K&N FIPK,SC Cortex 91 on 93, Super44 5" tips,35/12.5/17 BFG A/T's,3.70 Gears
Old 06-25-2013, 01:24 AM
Clifford05's Avatar
Clifford05 Clifford05 is offline
Vehicle: 2005 Ram Pick Up
Trim Level: SLT Sport
Rep:20
Clifford05 is on a distinguished road
Ok i see two issues: a 4x4 and 35" tall tires! With that set up I would do the gears, only down fall is to have to do 2 axles, double the cost! But if you have the cash that's what I would do first and then maybe a stall converter.
Think with those tires and gears a camshaft won't really help out, may run worse around town/bottom end. If you are just looking for this low end street performance kick do the gears.
If and when you go bigger with a cam you usually need a converter and gears to get it "up" quicker into that cams powerband. That's why when you read in the cam manufacturers footnotes some say need gears, stall, headers cause you want to get the motor RPM's up quick into where the cam makes power. Not that a 260 camshaft is all that crazy, but don't think you'll see as much as a result with gears and coverter. Goood luck and go with the gears.
Old 06-25-2013, 09:45 AM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
Originally Posted by MidnightHemi View Post
Where's the best place to pick those up?
All those parts can be picked up from the dodge dealers but they maybe running out since the 6.1 is no longer in production or some of the vendors can get them cheap. When i priced it for my 3rd gen it was like 200 bucks or less for everything but that was 4yrs ago.
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 06-25-2013, 02:34 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
I have a 4x4 with mud tires and I have a cam swap and 4.56 gears. Did gears first and I like them a lot but felt more from the cam. Glad to have both but if I had to do it again I would go cam first for the money
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
