Old 06-17-2013, 01:27 PM
StevieB StevieB is offline
Vehicle: 2004 Dodge Ram 2500
Trim Level: SLT Heavy Duty
Color: Maroon
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
StevieB is on a distinguished road
Default ABS Controller Electric Fire - Help please
I have had an electrical fire under the bonnet last week, luckily I managed to put it out before lots of damage. It appears to have started in the plug leading from the wiring harness into the ABS controller which sits on top of the ABS pump. The heat has melted the plug at the end of the harness connecting to the ABS controller and one of the two plugs on the controller together witrh some wiring insulation on the harness. Its bad luck though as here in UK you cannot get the plug seperately that leads from the wiring harness result is purchace whole wiring harness for the plug. Are there breakers yards in the US that sell seperately? I also need the identity tag for the wiring harness. Does anyone know where this is located on the wiring harness? I also need a new ABS controller.
My rig is a 2004 2500 5.9L Diesel manual. Any advice or assistence would be appreciated.
Old 06-19-2013, 10:48 AM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Do a google search for auto wreckers in the US and most of them will ship overseas. You will find that most are linked to a national data base and will show multiple facilities that have the parts you are looking for as well as 1-800 phone #'s.
