Transmission temp gauge help. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 06-17-2013, 03:36 PM
thekid0311 thekid0311 is offline
Vehicle: 2005 Doge Ram Quad cab 4x4
Trim Level: Daytona
Rep:15
thekid0311 is on a distinguished road
Default Transmission temp gauge help.
Ok I put a T fixture on my outlet line of my tranny. I used 3/8ths compression fittings to clamps down the ends of where I cut into the line and then I have a 3/8th to 1/8th reducer on the end that sticks up for my sender. Its been JB welded so I have a warm and fuzzy that it wont leak. Ive got it all wired up and ive got power and Im getting a temp reading of 68 on gauge but it doesn't move from there. I have the sender grounded to the O2 sensor of the cat. Is that causing interference and not reading a temp or is it just a bad sender? Thanks in advance for the help.
Men will follow out of fear but will die over respect
Old 07-14-2013, 09:04 AM
hriczko806's Avatar
hriczko806 hriczko806 is offline
Vehicle: 2004 Ram Quad Cab
Rep:91
hriczko806 will become famous soon enough
Dont know if your still having this issue... I just installed a trans temp gauge as well as the manifold.
First which line do you have the manifold tapped into? Is it the line going to or from the trans cooler? Also you said you have the sender facing up?
The manifold should be on the line from the transmission to the cooler. Also The sender needs to be pointed down so that the fluid can pool inside and it can get a proper reading. Do you have a digital gauge or analog? If it has a needle check the fitment of the gauge in the gauge pod. I saw on youtube a guy installed his and commented that he had his gauge installed too tightly and it was actually coming in contact with the needle so it couldnt move past a certain point. One last thing... I dont think it matters but I would try to ground it to something else. When I installed mine the sender had one wire that went directly to the gauge so I didnt have to ground anything on the manifold. Only what was required by the gauge.
Hopefully this helps you out a bit.
