Old 06-17-2013, 07:59 PM
TRK0225 TRK0225 is offline
Vehicle: 2007 Dodge Ram
TRK0225 is on a distinguished road
Default Headlights not working as they should.
When I use my key fob to unlock the doors only the drivers side headlight comes on. the same for the day time running lights and when I turn on the head lights only the drivers side low beam works. When I switch to High beam they both work. I am dazed and confused. I really do not want to go to the dealer ship. I really hate electrical problems, I get a headache just thinking about this. Has anyone else had this problem and can give me a sense of direction.
Old 06-17-2013, 08:17 PM
Ramageddon's Avatar
Ramageddon Ramageddon is offline
Vehicle: 2012 Dodge Ram
Color: Mineral gray
Rep:37
Ramageddon is on a distinguished road
You may have two bulbs per side, your low beam bulb may be out that's why the high beam is working.
Old 06-18-2013, 12:49 PM
Chris65 Chris65 is offline
Color: silver
Rep:45
Chris65 is on a distinguished road
Unplug the connector and check if you have power. If not, there is a high possibility that you need a tipm
Old 06-18-2013, 01:03 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
Yup, it's either a burnt out bulb on your passenger side low beam or a wiring issue. If you have a test light or volt meter I would test the wiring to the light first. If there's power there then it's just the bulb. Easy fix. If you don't have access to those tools then just replace the bulb and see if that fixes it. It's cheap to do.
Old 06-18-2013, 01:20 PM
Hey tried new bulbs(2), got power. What is a "tipm"?
Old 06-18-2013, 01:21 PM
Rep:2032
And they still aren't working properly?
TIPM = Total Integrated Power Module
Old 06-18-2013, 02:42 PM
Color: silver
Rep:45
Power on low and high beam or just on high?
Old 06-18-2013, 02:48 PM
Rep:2657
I sure would not take it to a dealership, i would go to an good auto electric shop
I made the mistake of buying a complete headlight unit from the dealership, online they are much cheaper in price
