Old 06-17-2013, 09:24 PM
2006ramhemi's Avatar
2006ramhemi 2006ramhemi is offline
Vehicle: 2006 Dodge Ram
Color: Gray
Rep:50
2006ramhemi will become famous soon enough
Default Wheel about to fall off
Had a real bad grinding sound coming from the drivers side front wheel and took it to the mechanic. he put it on the lift and the wheel was wobbling a good inch or so. ended up being a wheel bearing. i think i would have cried if it fell off
Old 06-17-2013, 09:31 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
I had the same thing happen to me on my old 4x4 s10 blazer except the rear drivers side wheel.
I knew it was going bad but I was younger and dumb and didn't change it out. By the time I did he said if i had hit a big enough pothole it would have fell off. The bearing was gone and grinded the axle... no bueno and very expensive.
Good thing you got your checked out in time!!!
New audio build in progress
