Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 06-19-2013, 12:44 AM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
Originally Posted by Screamintrashcan View Post
Spindle socket is 1 11/16. you may need to thin the wall a little, with a bench grinder, clearance is very limited. A torch may come in handy for burning out the joint, and getting the cups to release. Make sure the joint is all loose and free when you have installed all your circlips. if you have to spread the yokes a coupla thousandths, to get it all free and loose, do it, cuz any tightness will show in a hard turn, when that joint is really getting flogged. The brake shield may take quite a beating removing the bearing, but you can generally fix it. I have an air chisel with a custom ground 'chisel' which works great for popping the bearing out of its' close tolerance little home, just keep working around it, it'll come, but leave the screwdrivers in the toolbox, temptation will get the better of you, and you'll be snapping the ends off! Good luck!
In my case, there were no standard sockets available, so I bought a 43mm impact socket from carquest for $24. It was the only 6pt socket available...
Old 06-26-2013, 11:39 PM
Darrenwood128 Darrenwood128 is offline
Vehicle: 1995 Dodge ram 1500 4x4 5.2L
Trim Level: Larime
Darrenwood128 is on a distinguished road
Thanks, everyone... did them both and it was straight forward. Took a piece of highway sign metal post and braced it up to the hub bolts and cut the wheel and got the bearing half out... then it just pulled out. Turns out the previous owner must have replaced both hubs not to long ago as well as the brakes!!! To bad I have to sell it!!!
