Old 06-19-2013, 02:15 PM
galfer galfer is offline
Vehicle: 2011 RAM 1500
Trim Level: sport
Rep:13
galfer is on a distinguished road
I have to be missing something because even when I look up the specs on the fuel hostage chrome wheels like you got, im not seeing an option for a 20x9 with -12 offset..
im only seeing a +1 or +20 offset for the 20x9 wheels with 5x5.5 lug pattern..
can you guys help me out here? the fuel "Dune" in black/milled is what I want
thanks again
The 20x9 +1 offset will give you the least chance of rubbing since wheel is mounted right at the center.
As gonefishin776 said the 20x9 +20 offset isn't even an option, you'll never get 35x12.5's on there.
Once you jump up to the 20x10 wheel with a negative offset you're probably going to rub simply because they stick out so far. You'll end up hitting on either the back of the inner fender or the front valance.
Based on running Toyo MT 35x12.5 tires here's what you'll stick out on the front with each set up:
20x9 +1 offset: 1 5/8"
20x9 -12 offset (if that's available): 2 1/8" << This is the set up I'm running. Link in my sig with pics if you're interested.
20x10 -12 offset: 2 5/8"
20x10 -24 offset: 3 1/8"
So depending on what flares you want to put on those numbers should influence your decision. Bushwacker pocket flares stick out 2.5", OEM flares stick out about 2.0".
Old 06-19-2013, 02:21 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2051
thanks again
Ya, just looked that up on Fuels website as well.... it's possible that they don't list everything that is actually available. I know it's sometimes the wheels come with no bolt pattern and are drilled out later to whatever they need to be.
I would talk to Andrew or Jeremiah at Bully's Performance. They're the ones I got my wheels/tires through. See what they can find for you through their suppliers. They also have great pricing for wheel and tire packages
Andrew: fastNugly@bullysperformance.com
Jeremiah: jhinkle1989@bullysperformance.com
Old 06-20-2013, 01:29 PM
Trim Level: sport
Rep:13
awesome. ill shoot them an email.. thanks so much for all the help, I really appreciate it.
little off subject.. you ever get your new grill in? was curious if you ever figured anything out on getting that honeycomb one to me
Old 06-20-2013, 04:41 PM
Rep:2051
No problem.
It's supposed to be in today. I just took the old one out yesterday (so I'm driving around with a big gaping hole in the front of my truck. lol). I probably won't have time to get you any info until early next week. I'm busy tonight and then heading out on a trip for the weekend tomorrow. Once I have the box dimensions and stuff I can get a shipping quote to see what the approximate cost will be.
Old 06-20-2013, 11:15 PM
Trim Level: sport
Rep:13
sounds good bud. look forward to hearing from ya
