Vararam install question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > VARARAM - Dodge Ram Performance!
Diesel Forums!
Dodge Caliber
VARARAM - Dodge Ram Performance! Vararam Industries was created to bring true racing technology to the street, the most efficient air induction systems on earth. Our air induction systems produce more Power and Torque, offering you more real world performance than any of the other intake system out there, We've been tested to be the best, compared to the rest and each time VR comes out on top. - Dodge Ram Performance!
Place your Ad Here!
Old 06-18-2013, 11:54 AM
stryker291982 stryker291982 is offline
Vehicle: 2015 Dodge Ram REBEL
Trim Level: REBEL
Rep:12
stryker291982 is on a distinguished road
Default Vararam install question
First off my truck is a late 2012 model
To those of you that have installed this already when attaching the front air wing do you put the screw inserts from the back through the hole with the screws and washers in the front or do the inserts go on the front side with the screws on the back.
either way looks like the air damn is hitting on the ac lines one the passenger side
the installed instructions are not clear on this and the copied black and white photos suck at showing any detail.
Also I unclipped the wiring harness and moved it in front of the horn assembly is there anything else required to do with this or the horn seems like an awful restrictive place to have air flow pass through with the horn and wiring in its path.
2015 Ram 1500 REBEL, Hemi, 3.92, Solid Black.
Old 06-18-2013, 12:55 PM
Designflaw's Avatar
Designflaw Designflaw is offline
Vehicle: 2013 Ram 1500 4x4 Sport
Rep:40
Designflaw is on a distinguished road
Don't know if its right or wrong, but I put the screws and washers to the front. Also, the AC line I pushed the mounting bracket down about 1/4-1/2" at the fender and everything fit fine. You can see my PVC filter on the left vs. the right (before I cut it back some) I wanted to keep the Engine Cover without cutting it at the new filter location next to the Oil fill, so I just used the whole pipe brought it back over to the left side, drilled a small hole in the cover and used a wire tie to hold the pipe in place, cut the pipe back to the cover, then used the boot and filter.
2013 CC Sport 4x4: 3.55, 20% Tint, Line-X, fender flares, mud flaps, Weather Techs, bed cover, 2.5 Leveling kit, Blacked out emblems, Vararam Air Grabber
2008 M109R LE, 1999 TL1000R, 2003 Yamaha Golf Cart :hah:
Old 06-18-2013, 01:15 PM
billhere's Avatar
billhere billhere is offline
Vehicle: 2012 ram 1500 Quad Cab 2wd
billhere is on a distinguished road
Stryker:
Per Patrick (Vararam Tech), he likes the front wing mounted in front... Screws coming from the engine side to the front...
It looks like all Gen4 Vararams on the 2012's are hitting the AC lines on the passenger side... I trimmed mine out with a rotary cutter to remove the bind and which added more clearance on the passengers side.
It is because Mother Mopar moved the engine over 2 inches towards the passenger side on the gen 4 trucks and Vararam is still running their stock base unit setting centered on the engine but 2 inches off center of the truck...
I also moved the horn wiring behind the wing, to get it out of the airflow....
Good luck on yours, as I'm still fighting mine to make it work as I think it should work...
Bill
FM 50HD, Resonator Delete, De-badged, Jet180, BT Catch Can, Trinity/HF 91 tune, Bakflip G2, S&B CAI
Old 06-18-2013, 01:31 PM
Ezekielguy86 Ezekielguy86 is offline
Vehicle: 2012 Dodge Ram 1500 5.7 HEMI
Trim Level: ST Express
Rep:71
Ezekielguy86 will become famous soon enough
I too just installed my Vararam yesterday and was disappointed in the fitment of the front scoop on the A/C. Not a big deal I guess as i will just trim the scoop. My big issue was the wiring to the horn as stated above. The wiring blocks all the potintal air to pass threw. So I will be moving this as well. All in all its still a very nice well built intake that Im happy with other than the small issues.
Side note if your looking at this intake and are wanting it too be loud this is not it. As I didn't want to hear my intake non stop I was rather surprised on how quite it is. "can't tell any difference over stock sound"
Diablo Sport Intune HemiFever 93, S&B Intake, 14" Jones Full Boar, Mag Y Pipe, 180 T-Stat, Billet Catch Can, Pioneer 5500BHS, Fox Box W/ Type R, Air Lift 1000
Old 06-18-2013, 02:25 PM
Trim Level: REBEL
Rep:12
To all that have replied so far is thing supposed to look a little offset and not straight when looking at it from the front
Old 06-18-2013, 02:46 PM
Designflaw's Avatar
Rep:40
As you can see in my picture, it sits level, but to the left
