Old 06-18-2013, 04:12 PM
Dodgeram961500's Avatar
Dodgeram961500 Dodgeram961500 is offline
Vehicle: 1996 dodge ram 5.2
Dodgeram961500 is on a distinguished road
Default Need help
Alright I'm new to these forums . I have heard no one really replying but it's worth a shot I drive a 1996 dodge ram sport (single cab) with the 318 5.2 magnum with true dual glasspacks with turn downs before the back axel (loud and proud) it's a great truck and runs smooth until it decide to idle real low some times and when I drive it will cut back when I'm trying to drive sometimes it seems to cut back and not wanna drive smooth but it doesn't do it long just trying to find the problem hopefully ill get a response thanks
Old 06-18-2013, 08:24 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Could be any one of a number of things. O2 sensors (how much mileage on them?)? Failing intake plenum gasket? Need a tune up? If it hasn't had the intake plenum gasket repaired, I'd deal with that first.
Old 06-19-2013, 11:41 AM
Is it something I could do myself. Changing the gasket ? The truck has 157xxx on it
Old 06-19-2013, 11:44 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The low idle sounds like the IAC to me but it doesn't rule out the plenum gasket. Remove the air cleaner and get a good look down inside of the TB (hold it all the way open) at the plenum plate to see if there's any oily residue indicative of it being bad. I've also run across a low idle issue from a bad upstream 02 sensor. Try unplugging the 02 sensor and check for any difference.
Old 06-19-2013, 02:05 PM
appreciate the help ill go try that now!
Old 06-19-2013, 02:21 PM
I think when I got my new exhaust installed they took the o2 sensors off it is on the pipe right .?
Old 06-19-2013, 03:31 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
If you still have cats on the truck it should have an O2 sensor and another after the cat.
Old 06-20-2013, 08:08 AM
It has no cats. It's two 6 foot pipes to a glass pack turndown
Old 06-20-2013, 12:40 PM
Vehicle: 95
Rep:1776
I think what he's asking is if they also put the 02 sensors back in the system or just deleted them.
Old 06-20-2013, 07:13 PM
Rep:85
I'd be re-visiting that shop and wouldn't leave until they made good on re-installing the primary O2 sensors if they removed them. It's not going to run properly without them.
