Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 06-18-2013, 11:59 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
Default HVAC blend door issue?
Hello everyone,
what sorts of symptoms are associated with the AC blend door issue?
my truck today started rattling, popping, and snapping when I first start it up. It'll do it for about 10-15 seconds and it sounds like it's coming from behind the AC controls
I've also noticed that the "where at blows knob" doesn't always redirect the air flow, for example when on defrost it still blows out the vents, and when on floor it does the same thing to a lesser degree.
I'm hesitant to abirtrarilily bring it to the dealer as my warranty expired in March
thanks
Exco
Bill
Old 06-19-2013, 09:01 AM
Asur Asur is offline
Vehicle: .
Rep:4371
Maybe you should PM the OP of this thread, he is replacing his. He could probably give you info on how his started.
http://www.ramforumz.com/showthread.php?t=144810
Old 06-19-2013, 09:18 AM
sandawilliams's Avatar
sandawilliams sandawilliams is offline
Vehicle: 2014 2500
Rep:12
sandawilliams is on a distinguished road
Chrysler has been repairing these free of charge. Make sure the dealer reads through the entire TSB.
Old 06-21-2013, 07:03 PM
Excoastie's Avatar
Rep:1358
Thanks for the info and the responses.
I decided to pretty much just take a chance, as I didn't really feel like dealing with it myself. I brought the truck up to the dealership this morning.
I got a call about 2 hrs ago. They have the truck fixed! It was covered under warranty. I'm not sure if it's because they're aware that I tend to kick up a big fuss, or if it's a known problem that it's easier to fix and be done with it or what ever. My warranty expired 3 months ago.... even though I only have 26K miles.
A/C recirculation and temp actuator failure was what was causing all of the snapping, cracking, and popping.
All is good now
Exco
Bill
