Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 06-19-2013, 11:09 AM
CmRam's Avatar
CmRam CmRam is offline
Rep:52
CmRam will become famous soon enough
Default 1/4 mile time
Thinking about taking my truck to the track this Friday night. Just was wandering what ballpark et I should be running I have 3.55 gears, vararam air grabber, moes 87 mm tb, magnaflow mufflex, superchips flaspaq, and 180 stat. I know there are many variables involved, anybody with same mods and your times? I'm at sea level too
Old 06-19-2013, 03:07 PM
Mike.brewer03's Avatar
Mike.brewer03 Mike.brewer03 is offline
Vehicle: 2013
Trim Level: R/T
Mike.brewer03 is on a distinguished road
hows that Vararam Air Grabber?
Old 06-19-2013, 03:14 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
superchips allows you to take elapsed time trials if you want to try them out.
Old 06-19-2013, 03:55 PM
CmRam's Avatar
Rep:52
I like it alot, i like how it seals up against the bottom of the hood so it only sucks in cooler air fr outside instead of all the engine heat. I paired it with my tb at the same time
Old 06-19-2013, 03:56 PM
CmRam's Avatar
Rep:52
Even on the flashpaq?
Old 06-19-2013, 04:02 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I know when i had a flashpaq i was able to do 1/4 times on it..
Old 06-19-2013, 04:07 PM
CmRam's Avatar
Rep:52
Ok I'll check it out, hopefully I can get in the mid-low 14s
Old 06-19-2013, 04:52 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
4dr or 2dr?
4wd or 2wd?
20's or 17" wheels?
I've got 3.55's in my 10' RCSB 4x4,
with intake/exhaust/93 tune I got: 14.4's - 14.5's on stock 20's/33" rubber
Swapped on a set of 4 - 28" DR's on light weight aluminum 17's and got into the 13's.
But that's at 2500' DA, according to Dragtimes...
my best run 13.89/98.5 after DA corrections is 13.4/102mph
Old 06-19-2013, 06:13 PM
CmRam's Avatar
Rep:52
4dr or 2dr?
4wd or 2wd?
20's or 17" wheels?
Qc, 2wd and stock 20's
Old 06-19-2013, 06:44 PM
Rep:561
Can you get 93 octane gas? If so, load up the 93 tune
Set your rev limiter to max, 6400 rpm on a Superchips tuner iirc
and start with your shift points for 1-2 around 6100 rpm, 2-3 at 5900.
To save a little weight make sure you only have a quarter tank of fuel, and remove your spare
(every hundred pounds of weight reduction will reduce your ET by a tenth.)
Should be good for low to mid 14's if you get a cool evening.
My best guess, 14.4's if you're new to the track , then you'll be back many times and hundreds of dollars later until you break into the 13's.
you'll bask in the glory of that elusive 13 slip for about a year once you get it, and you will be happy
...but if you're unfortunate like some of us, you'll get a craving for 12's eventually, and that will cost you thousands instead of just hundreds.
