Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 06-19-2013, 06:02 PM
CmRam's Avatar
CmRam CmRam is offline
Rep:52
CmRam will become famous soon enough
Question
Can you get 93 octane gas? If so, load up the 93 tune
Set your rev limiter to max, 6400 rpm on a Superchips tuner iirc
and start with your shift points for 1-2 around 6100 rpm, 2-3 at 5900.
To save a little weight make sure you only have a quarter tank of fuel, and remove your spare
(every hundred pounds of weight reduction will reduce your ET by a tenth.)
Should be good for low to mid 14's if you get a cool evening.
My best guess, 14.4's if you're new to the track , then you'll be back many times and hundreds of dollars later until you break into the 13's.
you'll bask in the glory of that elusive 13 slip for about a year once you get it, and you will be happy
...but if you're unfortunate like some of us, you'll get a craving for 12's eventually, and that will cost you thousands instead of just hundreds.
I'm sure I will, modding is so addicting and fun especially after this first time at the track like you said. As for the 93 tune, I had it loaded a while ago with 93 octane, yet my truck didn't seem to like it at times actually felt a little slower than 91 tune, so I've just left it on 91 tune,Maybe i had a case of spark knock.
Old 06-19-2013, 07:22 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
You really do need good fuel to run a 93 tune, nice to have 1 grade higher than your tune to prevent knock.
I have 94 octane available locally, and Data logged a few runs with my Diablo Trinity and I never see any LT Knock Retard, and only 0.5 degrees ST KR at the worst.
Old 06-19-2013, 08:22 PM
CmRam's Avatar
Rep:52
Ok, I'll have to check that out thanks for the info, ill post my times after my trip to the track this weekend
Old 06-20-2013, 08:04 AM
compressor man's Avatar
compressor man compressor man is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Sport
Color: silver
compressor man is on a distinguished road
In the Texas heat I doubt you will see mid 14's first time out, more like low 15's with no prep in the heat. Prepped maybe 14.9's, the heat kills these things.
FRI'D 2007 RAM SLT SPORT 4x4 in the 13's
Old 06-21-2013, 01:21 PM
CmRam's Avatar
Rep:52
Got some crappy times using the sc for some quick testing at lunch break with a buddy in the truck too. 60 ft was 2.74, 1//8 mile was 10.16@76 and 1/4 mile was 15.73@92 was on just open road and it is in the high 90s but thought it would still be better than that
Old 06-21-2013, 10:45 PM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
^^That's about right for this weather. I feel like I lost 50 horses in the past two months. we get hot and humid but we are close to sea level in S.C. I have yet to take mine to a track, looking forward to it.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 06-24-2013, 05:06 PM
Chefalan23 Chefalan23 is offline
Vehicle: 2009 ram rt
Trim Level: Rt
Rep:51
Chefalan23 will become famous soon enough
This is true, hemi's get a little winded in the heat. Wait until the fall and take it on a nice cool 70* night.
09 r/t, Diablosport intune, Flowmaster super 10, $35 ghetto intake mod
Stock 4.10s and 2800 stall
Old 06-24-2013, 09:06 PM
Rep:63
^ Yep, early spring and late fall my truck will bark 2nd with the t/c on. I wound out 1st and 2nd just the other day, it was depressing.
Old 06-25-2013, 12:29 AM
Clifford05's Avatar
Clifford05 Clifford05 is offline
Vehicle: 2005 Ram Pick Up
Rep:20
Clifford05 is on a distinguished road
Ahhhh THE NEED FOR SPEED!!!
