Can my truck haul this???? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 06-19-2013, 06:02 PM
Socalgordon Socalgordon is offline
Vehicle: 2014 Dodge Ram 1500
Trim Level: Big Horn Crew Cab
Rep:126
Socalgordon will become famous soon enoughSocalgordon will become famous soon enough
Default Can my truck haul this????
I am looking into a toy hauler to lug band gear around and have a place to chill before and after gigs that do not provide a green room.
Will my 2012 ram 1500 crew cab big horn 5.7 with 3.55 gears tow something like this??
info 2001 Carson Fun Runner Toy Hauler
Great shape, ready to go play.
Outside is flat painted aluminum sides
5.5 KW Generac generator with ONLY 71 hours. with 20 gal tank.
Inside linoleum flooring is in great shape,no holes or tears. Some minor stains. Comes with carpet that has been stored not used.
A/C
50 gal fresh water
27 gal black and grey storage
dual axle
tire have lots of tread, approx 3 years old. no weather cracks or holes.
Double Stainless Steel Sink
Formica Counter Top
Smoke Tinted Windows
Day & Night Shades
Stereo System Pre-Wiring
TV Antenna / Cable Pre-Wiring
Air Conditioner
4-Function Monitor Panel
On-Demand Water Pump
6 Gallon DSI Water Heater
Wet Bath
Furnace
3-Burner Cook Top
6.3 Cubic Foot Refrigerator
Full Linoleum Flooring
Decorative Wall Paneling
Sliding Kitchen Window
Overhead Cabinets on Both Sides
Queen Size Pull Down Bed
Mirrored Wardrobe Closet
Side Awning
Exterior Shower
Two Convertible Dinette / Bed
12V DC Interior Lighting
Dual 5 Gal. Propane Tanks
Raised Roof
Cable Assisted Ramp Door
4 Wheel Electric Brakes
Lockable Service Doors
60 Amp Converter w/ 12V Battery Charger
Stand-Up Shower
Chrome Wheels
Tie Down Anchors
Deep Cycle Battery
R-7 Insulated Walls & Ceiling
Emergency Escape Hatch
dry weight approx 5,500 lbs
GVWR 9,995 lbs
Comes with Hitch, Load Leveling Bars and Stablizers
Old 06-19-2013, 06:18 PM
Rep:2954
that would be about 7,000 pounds loaded
max towing is 8,700 pounds
move the slider for the number of people that will be in it
check out this site
http://www.ramtrucks.com/en/towing_g...ion=light_duty
i filled out this info
2012 Ram 1500 Big Horn®
5.7L HEMI® V8 MDS VVT
crew 5'7" auto 4x2
3.55 axle ratio
Max Payload
1,630lbs
Max Towing
8,700lbs
Max GCVW
14,000lbs
Old 06-19-2013, 06:30 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
I don't see why it couldn't. You should be good to go!
Old 06-19-2013, 10:34 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
should be fine, just dont load the shit out of it, like filling the back end with amps and speakers, and youll be fine
Old 06-19-2013, 10:58 PM
h2oman's Avatar
h2oman h2oman is offline
Trim Level: Express 4X4
Rep:418
As long as you keep the groupies down to a dull roar you should be gtg.
Old 06-20-2013, 02:13 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Love it And agreed your truck should do it
Old 06-20-2013, 01:06 PM
Rep:126
Thanks everyone. I could tell by the numbers that I was pretty much ok, but I have not towed anything in over 15 years (last time I towed was when I owned a 97 ford f150.) I wanted to make sure from y'all.
The band gear is not much weight at all, I would say no more then 1,750 lbs (risers, complete drum kit, bass rig, guitar rig, 88 key rig, merchandise rig, drum tech rig, bass and guitar tech rig and A/V control rig.)
Sounds like a lot, but its really not. All this could fit in the back of a 15 passenger van (with rear seat taken out), grant it that some things are taken out of the road cases and it becomes a band version of tetris getting everything to fit just right.
The bed of the truck has the tonneau cover and that is for luggage and stuff that we can get to at moments notice.
Old 06-20-2013, 01:35 PM
Rep:126
Is there anything I need to make towing this (or something similar) better? brake controller?
Old 06-20-2013, 04:38 PM
Moderator
Rep:2140
It comes with the WD hitch so you're good to go there. I'm assuming it has electric brakes so if you're truck doesn't have a brake controller you will definitely need one.
Old 06-21-2013, 06:55 AM
slingshot383's Avatar
slingshot383 slingshot383 is offline
Vehicle: 2011 Ram 3500
Trim Level: Laramie Longhorn
Color: Black/ Gold
slingshot383 is on a distinguished road
You need a brake controller for the trailer brakes, a Weight distributing hitch would be a good thing, you might want to put a Titan gas tank in as that factory tank will become small when you're towing as the Hemi will pull the load, but it will burn the gas.
