Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 06-19-2013, 11:04 PM
AzDusty's Avatar
AzDusty AzDusty is offline
Trim Level: Laramie Longhorn
Color: Deep Cherry Pearl/Gold Two-Tone
Rep:37
AzDusty is on a distinguished road
Default oil ??`
Ok, not knowingly I have never ran synthetic oil. So does the 1500 come from the factory with Synthetic or regular. What are the biggest benefits of Synthetic? Does this extend the time between changes? And (IF) I get a diesel (my first ever) does this come with different oil requirements?
You guys have been a wealth of knowledge and I am almost certain I will be driving a 2014 early next year.
I have one of the best wives on earth, we are heading to Phoenix this weekend for a small get-away and She offered to go to a Ram dealer and get this Test Drive a 1500 I hope they happen to have a Laramie Longhorn with the Air ride. But it will be fun either way. Top that off with a stop at Bass Pro Shop and then we are off to Wildhorse Casino to watch Rage in the cage (think UFC Minor Leagues)... What a great weekend.
RAM 1500 4x4 Laramie Longhorn
Old 06-19-2013, 11:24 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
I believe the truck comes from the factory with Dino oil.
As far as your other oil questions this topic is a very frequent one already. Check out the Ramforumz Oil Change Section. That area will probably answer your questions.
Old 06-19-2013, 11:26 PM
Grubrunner's Avatar
Rep:3883
Agreed.
There are countless threads on this very topic that should answer all of your questions.... and some more.
Good luck.
Grub out!
Old 06-19-2013, 11:28 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Dino in all but don't know about the 2014, probably Dino.
+1 on the countless threads, best you check those out than repeat what has been said and over said.
Old 06-19-2013, 11:30 PM
DWWHemiguy's Avatar
DWWHemiguy DWWHemiguy is offline
Vehicle: 2012 Ram
Trim Level: Express Quad Cab
Rep:37
DWWHemiguy is on a distinguished road
Wow a test drive, a casino,and Bass Pro shop all in one weekend. Sensory overload!
Old 06-19-2013, 11:44 PM
Trim Level: sport
Color: green
Rep:643
i use syn. started using syn , mobil1 in the early eighties when it was a very big step up. dino has improved greatly and you can't go wrong with either. in case you care, i use penzoil ultra and an overpriced quality filter. oci every 7 thousand miles.
Old 06-20-2013, 12:39 AM
AzDusty's Avatar
Rep:37
You know as many times as I have been reminded about the search feature you would think it would have found a place to stick on one of my two brain cells. I apologize for not using Search to my advantage. (ok that and I am trying to pad my post count so I can pm people)
Old 06-20-2013, 04:51 AM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Well, Mobil 1 is recommended by Porsche, and it's cheap, so that's what I use. I'm actually a little surprised that Ram isn't doing factory fill synthetic, since I know Ford and most of the others are at least using a synthetic blend.
Old 06-20-2013, 08:32 AM
Vehicle: .
Rep:4371
What are you trying to do, post count what? oh, maybe you can explain in another post
Old 06-20-2013, 08:55 AM
Sundog's Avatar
Sundog Sundog is offline
Vehicle: 2005
Trim Level: Custom
Sundog is on a distinguished road
Smile switched
I switched from Dino to Synth oil a year ago and change it every 5,000 km. I have noticed a difference in the oils "cleanliness", not almost black as when I used the non synth, now it looks almost as clean as when I pour it in.
