Old 07-01-2013, 07:13 PM
Red-Stripe Red-Stripe is offline
Vehicle: 2012 ram
Rep:117
Red-Stripe will become famous soon enoughRed-Stripe will become famous soon enough
Originally Posted by ArmyofOne View Post
I was watching the injectors pulse on the scope in the shop. Every time the tick was audible with the truck on the dyno, a spike showed on the scope. The injectors in the Hemi's with MDS "tick" when the fuel in the rail bypasses the injector because its closed. I cant really think of any other way to explain it, but my dealer spent 35 days and went to great lengths, even paying for dyno time at a contracted shop, to get to the bottom of the ticking noise described, and that was the verdict. If you don't buy it, I don't know what to say, other than I dont know why a dealer and the service manager would willingly go that far to get to the bottom of it and then give me the wrong answer. They drove new trucks, and used trucks, and my truck. They had my truck hooked up and then hooked up a new one for comparison, and mine checked out with nearly identical results and readings to every truck it was tested against...6 in total (3 brand new and 3 used 4th gens).
Call me a skeptic.
As far as I know, when decelerating from 60, as the OP wrote, ALL injectors would be de-activated, not just the MDS ones. That alone rules out this theory. Cars have been cutting injection during deceleration for years now. Also, under light throttle the majority of fuel bypasses all the injectors anyways, so that's nothing new. Add this: If you saw a spike on an O-scope- how could you see it if it wasn't being fired? Also, all the engine parts are still moving at rate, so a spike on a scope could appear to you to align with any event. But mostly, an unpowered injector has no electrical pulse applied, and would have zero uncompressible fuel movement as a result, so I can't see it from my house. Maybe, with a stretch just maybe a fuel rail line, or hose. There has to be physical movement to create noise.
Old 07-01-2013, 07:48 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:441
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
My 05 non mds hemi has developed a slow tic at idle, about 1 tic per second, also cyl 8 misfire. Borescoped #8 cyl, it's perfect. I've bought lifters, head gasket and all parts to pull off the passenger side head, hoping it might be a rocker arm. My gut tells me it's not a lifter. Probably can't get to it till after the 4th of July, but I'll post up what we find.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 230,000 miles To Hell and back. 14.2/96 mph NEDW
Old 07-01-2013, 11:23 PM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
hydrex, how many miles on the 05?
Old 11-18-2013, 09:52 PM
CoryBenge's Avatar
CoryBenge CoryBenge is offline
Vehicle: 2011 ram laramie
CoryBenge is on a distinguished road
Mine was just in the shop. MDS Cylinder 1 failed so they replaced that and the wire harness. Put back together and noticed the ticking noise I was also complaining about. Doubted it was an acceptable tick so they tore into it deeper and found one bent valve guide. I dont know much about the heads but they said they had to replace the head, GREAT FOR ME NO MORE TICKING
Old 03-03-2015, 11:41 PM
dodgeshawgo dodgeshawgo is offline
Vehicle: 2011 dodge ram 1500
Color: maroon
dodgeshawgo is on a distinguished road
I been having this same issue and been going rounds with mechanics. Final one is telling me it is ticking from eco mode kicking in and it's normal but normal or not it's embarrassing to say the least. It's like driving through parking lot in pinto with rods knocking but in a $35,000 truck with 50k miles.
Old 03-04-2015, 01:29 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
My 2011 Ram has been doing this more often lately. I knew of the Hemi tick (not first or only Hemi ~ ), but figured it was MDS related. It does go away when you use gears vs. drive.
62,xxx miles on truck.
Yeah it sucks when driving around, I wonder how loud it is for others vs. how loud it is in the cab.
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
