Old 01-19-2014, 12:27 PM
ramSpoons ramSpoons is offline
ramSpoons is on a distinguished road
Default Wiring a Back up Camera
I have a 2009 SLT Quad Cab and am in the process of putting in a new back up camera, but got stuck when I was looking for a way to get the wires in to the cab. Does anyone have suggestions as to where there is an existing hole or where I should drill to run the wire from the bed in to the cab.
Just some info on what I am installing. Its a simple after market camera and monitor integrated in to a rear view mirror. I am running the wire from the camera to the mirror and just need help getting in to the cab. Thanks in advance guys
Old 01-19-2014, 05:05 PM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
Nipple on bottom of wire harness rubber seal just cut the end off or the plug for the clutch rod ? if you have a auto trans. Both are on the drivers side of the firewall.
Old 01-19-2014, 05:13 PM
Rep:2657
there is a youtube video on how to run the wiring for back up camera to the rear view mirror
Old 01-20-2014, 01:28 PM
Lifted Cummins Fanatic
Rep:2032
Yup, that's where I put mine on my 1500. Great place to run any wiring through the firewall.
Old 01-20-2014, 01:37 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
I ran mind up through the grommet under the driver side rear storage bin. Just lift up the covering material. You can then run the wiring under the door sills with the factory wiring harness. There is an opening at the bottom of the storage bin to get the wires through.
