Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram – 1993 & Older Dodge Ram Trucks > Towing
Towing 1st Gen Dodge Ram Towing Questions
Old 06-21-2013, 12:40 PM
PowerRam85's Avatar
PowerRam85 PowerRam85 is offline
Vehicle: 1985 Dodge W350
Color: Blue
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
PowerRam85 is on a distinguished road
Default Towing + No Brakes = Hiroshima!!
I haul my 20ft bay boat around quite often, and usually use this one ramp on base that's real close to my house. The ramp is pretty steep but convenient enough because of it's location. Last weekend I hit the road early to get my morning fishing on and as I was reversing to the ramp my brakes go out. Luckily, I put it in drive and was able to make it out before I hit the water.
After some diagnosing, I realized that my combination valve's pin was stuck out, and by the looks of it wasn't going to be easy to reset (Rust). I hit the junkyard for a new combination valve after weeks of trying to find an OEM replacement and I got lucky finding an 89 Ramcharger. I got a good deal for $2 because apparently the guy at the counter didn’t have a clue to what it was. Installed it and no luck again...
So I decided to buy a new aftermarket one from Summit Racing: Classic Performance Brake Proportioning Valve, P/N: PV-2. It is identical in every way to the original configuration and it also bolts right up to the original bracket. The only thing I had to swap was the warning light switch. For only $45 I would definitely recommend this to anyone still dealing with their old steel combination valve on their second generation.
Just my two cents.
Old 06-21-2013, 05:29 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
when was the last time you changed your brake fluid? i have never had an issue with the proportioning valves on any of my trucks.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 06-24-2013, 05:03 PM
PowerRam85's Avatar
Color: Blue
I checked it about five months ago when I first got the truck..
Old 06-24-2013, 10:08 PM
but have you actually changed it? up here in the land of rust we usually replace our brake lines about every 10 years and with doing that we have no choice but to change all the fluid. over time brake fluid absorbs water. water will create rust even if it is to the parts inside the brake lines. i think even at one point in time they recommended changing the brake fluid every 2 years because of this.
Old 06-25-2013, 11:51 AM
PowerRam85's Avatar
Color: Blue
Yea, I definately know about rust, it's pretty common killer over here by the coast. I ended up replacing all of my lines because they were too corroded.
Old 06-26-2013, 05:10 PM
RickinWA RickinWA is offline
Vehicle: 2013 RAM 1500
RickinWA is on a distinguished road
Default Towing: Using the "Gain Adjustment" power output
RE: Integrated Trailer Brake Controller - How to set & vary the "Gain Adjustment" power output under varying road conditions.
First, I’m a first time truck owner as of 2 weeks ago purchasing the RAM 1500 SLT Crew Cab 4x4, V8 Hemi, towing package, with Integrated Brake Controller.
Second, “We” just purchased our first travel trailer (Denali 246RK) and will pick up this Friday (June 28th).
Question: What power output settings (+ or -) are made with the “Gain Adjustment” under varying road conditions? Is there a setting or range for towing on level road, a different range/setting going down a 8% grade hill vs 15% grade, or going the opposite uphill? Or, is it done all automatically?
Question: Is this correct? I first hook up the trailer, drive on a level road at 25 mph, and manually squeeze slowly (?) the Gain Adjustment lever using no truck brakes, and the brake controller will automatically stop the trailer, w/o squealing the tires. Then, the brake controller will display the correct setting to use? Again, that number would be for a level road. I’m more confused by any adjustments to be made under different road conditions.
This is all new to me!
Much thanks!!
Old 04-23-2014, 07:09 PM
USAF Long's Avatar
USAF Long USAF Long is offline
Vehicle: 2013 Ram 1500 RCSB
Rep:69
USAF Long will become famous soon enough
Send a message via AIM to USAF Long
Rick, you posted this in the 1st gen forum, try the 4th gen towing forum and make a new post here: http://www.ramforumz.com/forumdisplay.php?f=202
-Scott Long-
2013 Ram Express RCSB: 5% tint, de-badged doors, muffler delete y-pipe, K&N panel filter.
Best Run: 14.60@96mph with 2.4 60' at Kil-Kare Raceway in Ohio
