Old 06-21-2013, 01:34 PM
Nauvoo Nauvoo is offline
Vehicle: 2012 Dodge Ram 4x4
Trim Level: Big Horn Quad Cab
Color: Sagebrush Pearl
Nauvoo is on a distinguished road
Default oem 20" to 17" tire size question
If I go from 20" wheels to a 17" factory wheel arent I gonna loose 1" in wheel width? Hows this gonna affect my tires if I run a tire with basically the same measurements as the stock tires? Will it not create a balooned look? An 11" tread width isnt too wide for 7" wide wheels?
Air Intake Mod, K&N Drop-in, Catch Can, Flowmaster Super 44, Airlift 1000s, Cooper AT3s LT275/65r20, Draw-tite gooseneck hitch,
Old 06-21-2013, 01:53 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
Yes you will loose 1" in wheel width. That shouldn't make a difference in your choice for tire size. On a narrow rim you will just have a little more sidewall bulge than if you had the wider rim. Certain tires do have recommended rim widths so I would look into that as well. But you should be fine running an 11" tire on an 8" rim.
Also just to clarify, I'm assuming you mean the same overall measurements as stock. Because obviously you can't run the stock tires on 17" rims and likewise a 285/60/20 is not going to be the same size as a 285/60/17.
Old 06-21-2013, 02:00 PM
Designflaw's Avatar
Designflaw Designflaw is offline
Vehicle: 2013 Ram 1500 4x4 Sport
Rep:40
Designflaw is on a distinguished road
Depending on what manufacturer, just order a 17x9
2013 CC Sport 4x4: 3.55, 20% Tint, Line-X, fender flares, mud flaps, Weather Techs, bed cover, 2.5 Leveling kit, Blacked out emblems, Vararam Air Grabber
2008 M109R LE, 1999 TL1000R, 2003 Yamaha Golf Cart :hah:
Old 06-21-2013, 02:02 PM
Rep:2036
OP is talking about the OEM 17" wheels which are 8" wide.... Going wider isn't an option in this case.
Old 06-21-2013, 02:08 PM
Designflaw's Avatar
Rep:40
Missed that -
Old 06-21-2013, 07:38 PM
Yea i was referring to running a tire thats essentially a 33x11 on a 17" wheel. Found a set off a'13 Ram, but theyre advertised at 7" wide and I thought the tires Id like to run might be kinda odd looking on that wheel.
