4.7 engine overheating. HELP!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Old 06-08-2013, 10:07 PM
jeff61611 jeff61611 is offline
Vehicle: 2005 dodge magnum rt
jeff61611 is on a distinguished road
Default 4.7 engine overheating. HELP!!
I have a 2002 dodge ram 1500 with the 4.7 it overheated today and spewed a Buchanan of coolant out of the cap. I replaced the thermostat and topped off the fluid, and bled the bleeder screw. I went for a drive and it overheated again I pulled over and bled the air out of the bleeder again and then let it cool down. Drove it home a few miles and it looked good until I parked then it started to rise again. Don't know what else to try if anyone can help or have any suggestions it would be greatly appreciated. Thank you
Old 06-10-2013, 07:39 PM
Moderator
Rep:2140
Have you checked to make sure your fan is working correctly? I'm not familiar with the 2002's but I'm assuming it has a thermoclutch fan. If that's not working you'll overheat constantly. Let your truck get up to operating temperature and see if the fan comes on fully. If not, that's your problem.
Old 06-12-2013, 07:47 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Did you replace the cap?
Old 06-24-2013, 06:58 PM
blkwdw86 blkwdw86 is offline
Vehicle: 2002 Ram 1500
Color: Maroon
Rep:21
blkwdw86 is on a distinguished road
A number of things it could be. And when you stop the truck, your temp will naturally rise as the heat from the block heats up the now not circulating coolant, it's normal.
If your truck overheats quickly when you start out, your water pump is toast. The engine superheats the coolant around the cylinders without the circulation needed to move it away and replace it with cooler coolant from the radiator. This is usually accompanied by a bubbling/boiling sound.
A blown head gasket will also cause your truck to overheat with similar symptoms, do a compression test.
If it overheats after a reasonable amount of driving, it's possible your radiator is plugged, have it cleaned or replaced.
What type of coolant is in it has an effect, too. Rams use a HOAT (Hybrid Organic Additive Technology) long-life coolant. Use of other types of coolant WILL affect the efficiency of your cooling system. I use Zerex G-05 coolant, available at NAPA for about $16 a gallon. Expensive, but necessary (everything for these trucks is expensive). If you're not using a HOAT type coolant or aren't sure what's in it, after you do any repairs necessary, drain and flush your cooling system with distilled water (no minerals in it) and refill with the proper coolant. Your truck will be MUCH happier with it.
