Old 06-22-2013, 06:01 PM
muliefever muliefever is offline
Vehicle: ram
Trim Level: Crew Cab Express
Rep:12
muliefever is on a distinguished road
Default running lights question?
So I have a new 13 ram 1500 and I just picked up my new TT yesterday. I had the dealer instal a electric brake module and when we checked everythng found out I have no running lights and the trailer 7 pin. Everything else works as it should. Any thoughts?
Old 06-22-2013, 09:12 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Possible wire that runs to the 7 pin not hooked up? Or came loose?
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 06-22-2013, 09:17 PM
Lobo Lobo is offline
Vehicle: 2013 Ram
Color: Grey
Rep:14
Lobo is on a distinguished road
I assume you got the brake controller to work. Some folks had trouble at first with aftemarket brake controllers on the 13's because they require a two connector harness so any brake controller will work but require a two connector harness. Are you saying you have the 7 pin trailer connector?
Old 06-23-2013, 02:24 PM
Vehicle: ram
Rep:12
Yes i have the 7 pin and four pin combo on the bumper of my truck. The trailer brakes are working as well as brake lights and turning signals.. I didnt notice any loose or unhooked wires. The service center at the RV center hooked it all up and I know it is pretty straight forward. I am not sure why I would all of the sudden not have running lights? Taking it back to the dealership Tuesday if I can't figure it out by then.
Old 06-23-2013, 07:46 PM
bigbody's Avatar
bigbody bigbody is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Black/gray
bigbody is on a distinguished road
Did you check the fuse for the trailer lights, sometimes there is more than one fuse for trailer running/brake lights
Fuse f29,f30,f53 all have to do with trailer tow
2013 RAM 1500 Laramie, sunroof, 3:55gears, undercover se, avs in channel, 30% tint all around
Old 06-25-2013, 05:58 PM
Vehicle: ram
Rep:12
Fuse F29!!! 20 AMP is blown. And guess what I can't find one anywhere!!!!
Old 06-25-2013, 06:02 PM
bigbody's Avatar
Color: Black/gray
Well that sucks that you can't find one, but at least you know the problem now, try the dealership I would hope they would keep some in stock
Old 06-27-2013, 09:43 AM
Vehicle: ram
Rep:12
So I had to order the fuse from RAM... Not a single dealership in Boise has one!!! I guess they are a brand new fuse for this year and haven't been distributed
