87 360 timing adjustment - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 06-26-2013, 10:31 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Sounds like around 1200 rpm give or take.
Old 06-27-2013, 10:26 PM
87flatbed350 87flatbed350 is offline
Vehicle: 1987 Dodge Ram D350
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
87flatbed350 is on a distinguished road
Ok, heres another update.
It ran jam up after replacing the ballast, icm and cap and rotor, no surging, no sputtering.
My dad went to the dump today and it started doing the same thing when he hit a hill, sputtering, losing power, and eventually dying... So he asked someone at autozone for their opinion, and they mentioned fuel lines. I had assumed that the guy that helped my dad get this truck running originally had thought to replace the fuel lines all over, but alas, he didn't..
So my dad replaced the lines from the tank to the electric pump, and the return line in the same place, all of which were so degraded, you could pinch them closed almost by looking at them.
I had hoped that would help/potentially fix the problem, but it didn't...
So I'm trying to think of what else it could be that would cause the surging and dying only when pulling hills...
Experience, schooling and logic tells me its a fuel delivery issue, but is it the mechanical fuel pump? Or is it the carburetor? IE sticky float, clogged jet?
I need to figure this out as it is his work truck.
Old 06-27-2013, 10:37 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
did someone use rubber line everywhere? should only use rubber line to connect the 2 steel lines.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 06-28-2013, 02:26 AM
Rep:99
Mech fuel pump would not be affected by a hill. Carb first. Just because you put a rebuild on it doesn't mean it's working properly. Failing that, consider a decayed fuel pickup and/or pickup screen in the fuel tank. Does it cut out the same on a 3/4 full tank as it does on a 1/4 tank when on a hill?
Old 06-28-2013, 06:52 PM
My wife suggested the same thing, and my dad said it still did it with a full tank yesterday morning.
My dad is supposed to hit up the pick a part to look for carbs and a harmonic balancer... but its 110 today...so not sure he'll get out of the house..
360, carburetor, timing
