Old 06-23-2013, 02:09 AM
Wyldkat Wyldkat is offline
Vehicle: 2010 Dodge Ram 1500 Quad 4x4
Wyldkat is on a distinguished road
Default time for service
Well after listening to the exhaust tick every morning for a bit I finally got the truck into the dealership for a look. Turns out had a couple broken studs, fixed under warranty at 95000km, no questions asked. Also had them take a look at front suspension as it feels a bit off when cornering but nothing found. My truck falls into the recall for the pinion nut but there is still no fix available from Chrysler.
Old 06-23-2013, 02:35 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Good to hear that the dealership took care of you. I've seen a lot of posts about this pinion nut recall. So how does Chrysler do a recall without a fix? That's kinda like wiping before you poop, it just doesn't make sense!
Old 06-23-2013, 02:40 AM
Rep:2657
exhaust manifold studs were an issue on the 2009 & 2010 HEMI engines
It sure is funny that Chrysler can't find anyone to make what is called a patch with some blue loctite embedded on it
or at least to peen the nut so that it can't back off
in racing they use something like a castle nut & drill through the pinion gear shaft & run a safety wire through it, no way it can back off then
Old 06-23-2013, 03:00 AM
I know, its not like its rocket surgery, there are a few possible fixes to it and any of them are better than waiting while more people have their driveshaft fall off. I really don't understand how hard it is to come up with a solution and implement it. They seem to be able to launch a completely new vehicle (Dart) in less time than it has taken to solve this issue. As far as the 'parts are not available' that is BS too, there are plenty of auto suppliers out there with capacity to produce whatever parts they need to fix this. There's just no profit in fixing a problem.
Old 06-23-2013, 11:10 AM
db1 db1 is offline
Vehicle: 2010 dodge ram
Trim Level: sport
Color: mineral grey
db1 is on a distinguished road
just wanted to ad something about your steering in corners. im having my steering box replaced. i have about an inch of play in my steering wheel and can really feel it in corners. not sure if thats what your going through.
DOSNT ROLE ON TEENAGE RIMS!
Volant cai , bt catch can,180 stat, Moes 85mm, Sonnex line booster, Superchip programmer Tranny upgrade , Bilstein shocks 25% stiffer springs, Air bags, 22" srt10 replicas matt black, magnaflow tru x muffler.
Old 06-25-2013, 08:02 PM
Jarhead75's Avatar
Jarhead75 Jarhead75 is offline
Rep:21
Jarhead75 is on a distinguished road
Had the tick on the exhaust and a problem with my front end 97000 miles. Covered under warranty new exhaust manifold gasket on the passenger side also replaced something with one of the a arms
