Old 07-01-2013, 09:12 AM
patricklee85's Avatar
patricklee85 patricklee85 is offline
Vehicle: 2009 Dodge Ram
Trim Level: SLT Big Horn
Color: Blue
patricklee85 is on a distinguished road
Originally Posted by Astartes View Post
everyone is always about buying a huge tire. #1 its expensive, #2 i like my look. #3 the factory size was 31" on the 2010. Sorry I cant buy the most brand new badass shit lol.
Not Hatin', Bud! Like I said, to each there own. But you are right, it is expensive. My 285/65/20 Goodyear Wrangler MTR Kevlars cost me about $1800. Worth it to me but maybe not everyone.
If it works, it works.
Old 07-01-2013, 04:19 PM
Salt And Vinegar's Avatar
Salt And Vinegar Salt And Vinegar is offline
Vehicle: 2012 Ram 2500 CCSB
Color: White/Silver two tone
Rep:41
Salt And Vinegar is on a distinguished road
When I had a 1/2 ton I had the same look. Looks a bit more like a muscle truck with an agressive 33 and 18" wheel. Not to mention slightly better milage and acceleration due to less rolling mass.
SouthBend Clutch, FoxShox, H&S, Sinister, Toyo, BDS, BushWacker, aFe, ISS-PRO, FuelOffroad, S&B
Old 07-02-2013, 03:57 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2051
Originally Posted by patricklee85 View Post
Factory tire size is 33, or damn close to. Dont get me wrong, to each their own...whatever makes you happy. But in my opinion, if your increasing your ground clearance, fit the biggest tire you can...within reason.
No need to get all defensive.... he even said whatever makes you happy, everyone has their own opinion on what they think looks good.
But you are wrong about the factory size on 2010 in some ways. You have a 4.7, so your truck came with 17" wheels which yes, do come with 31.5" tires. The stock 20's on 4th gens come with 33" tires. That's what he was referring too.
And "the most brand new badass shit" has nothing to do with it... so that just doesn't even make sense
Old 07-02-2013, 04:09 PM
Color: Blue
My mistake! 4th Gens with 17s are not common where I live, shouldn't have made the assumption. In that case, 33s are definitely an improvement. Although, I maintain my own opinion that if you can fit it, run it. No one ever regrets that.
Old 07-02-2013, 04:18 PM
Rep:2051
Yes for sure. It's a little detail that most people wouldn't pick up on. So no worries there.
But yes, I agree with your opinion about running a bigger tire size if you can. Especially on a lifted or leveled truck. But I understand that other people like other things and respect their opinions as well even if I don't like them.
Old 07-12-2013, 08:29 AM
Spike Spike is offline
Vehicle: 2013 RAM Big Horn 4x4
Rep:58
Spike will become famous soon enough
I am running 305/55R20's on with no leveling kit. They fit perfect and is basically a 33x12. No wheel spacer was needed.
2.5" Lift, 305 R20's, Winch, Softtoper,
K&N, ZJ in tow, German Shepherd co-pilot
Old 07-13-2013, 01:43 AM
texasmedic's Avatar
texasmedic texasmedic is offline
Vehicle: 2013 RAM 1500 4X4
Color: SILVER
Rep:78
texasmedic will become famous soon enough
Thumbs up
Thank you everyone for the advise
---Veraram---87mm PTB---2" leveling kit---3" PA Body Lift---Iron Cross Push Bumper--- 34 Inch LED Light bar---35x12.5 R18 Atturo Trail Blades---18" Black Ballistic Morax wheels---CB radio---Bullydog Tuner---Dash mounted GPS---
Old 07-19-2013, 12:03 AM
phobos512's Avatar
phobos512 phobos512 is offline
Vehicle: 2013 Ram 2500 4x4 CCSB CTD
Color: Maximum Steel
Rep:6
phobos512 is an unknown quantity at this point
texasmedic - you rocking a 1500 or a 2500/3500? Your info doesn't say. Everything folks said applies only if you've got a 1500...If you've got a 2500 or better you can run ~34s stock (285/75R17) without any issue...
Matt || 2013 2500 Laramie || CCSB 4x4 CTD || Maximum Steel || Nitto Terra Grapplers 305/70-17s
Old 07-23-2013, 01:22 AM
texasmedic's Avatar
Color: SILVER
Rep:78
sorry I thought i put it in my info I have a 1500
Old 08-14-2013, 05:50 PM
Kibagami's Avatar
Kibagami Kibagami is offline
Vehicle: 2012 Ram 1500
Color: Black,Silver
Rep:37
Kibagami is on a distinguished road
If you go for wider then 12" be careful about the actual size of the tire when choosing a spacer.
For exemple my Nitto Trail Grappler size is 35X12.5R20 but on the Nitto web site they say that the actual size is 35.04 high and 13.39 wide (I didn't measure it myself but just to be sure I got myself 10mm - 3/8in Hub Centric Spacer)
For comparison Goodyear Wrangler MT/R actual size is 34.8 high and 12.5 wide and Toyo Open Country M/T actual size is 35 high and 13.0 wide.
Normaly a 12" wide tire shouldn't need a spacer but people recommend a 1/4 spacer for a 12.5" tire because they assume that it's only half an inch wider (or 1/4 inch closer inside) but since all 12.5" aren't the same you might want to make sure you know the actual tire size and how much spacer you will need!
just my 2 cents
